Tire Size on Base Model Bronco
junghohwang
Jungho
Nocatee, Florida
2022 Ford Bronco
Newbie here all, I'm struggling to find concrete information on whether 35's will fit on a base bronco with the stock suspension.
Curious to see pics/opinions of other tire sizes as well. All feedback is appreciated!
Blackcat
South Carolina
2022 FORD BRONCO BASE 2 DOOR M/T
Not an expert, you definitely need to remove the crash bars to avoid rubbing. Folks on here have done it.
junghohwang
junghohwang
Jungho
Nocatee, Florida
2022 Ford Bronco
Thanks, I've heard that a lot. I've seen a lot of folks put 35s-37s on Broncos with aftermarket suspensions or higher trim suspensions, but cant seem to find folks with the Base models who put 35s on.
cyoungk
C
CA
Bronco Big Bend
You’ll need a lift, roughly 1.15” min on front but yes you can fit 35. I’ve seen people put on 37 even.
I have a Big Bend which is essentially the same car as the Base and I put on 35’s with a 2” lift.
junghohwang
junghohwang
Jungho
Nocatee, Florida
2022 Ford Bronco
Di
Did you put the 2'' lift all around? or just the front? Thanks in advance
cyoungk
C
CA
Bronco Big Bend
Di
I did all around but you can just level it with 1.5” on front if you want. That was originally the route I was going to go with.
Discount Tire
Arizona, USA
discountti.re
All Things FORD
As mentioned, a lift and modifications to the crush bars would be needed.
Also, if you plan on using the factory wheels you may run into an issue with tire size. The factory wheels are only 7-inches wide and most 16-inch 35's are not recommend for this width wheel (IE: 315/75R-16 | 35x12.50R-16).
