Triangle on Rear Passenger Window
CrownCityMisfit
Aaron
Pasadena, CA
Focus, Crosstrek
What is the purpose of the small triangle on the lower-back corner of the rear passenger window? Is it hiding something they couldn't design around? Guide for the glass?
photo by Mattwings
Ford Bronco Triangle on Rear Passenger Window iconic-silver-bronco-black-diamond-
VoltageDrop
Fidalgo Island, WA
23, 69 Bronco
That's a black diamond... The other 3/4 of it is inside the door.
Philly
Dallas, TX
2022 JL Rubicon
The bottom of the glass has to be cut on an angle so that when the window is fully rolled down it doesn't stick up at all. Unfortunately, this means when it is fully rolled up there would be a hole so that plastic piece is there to cover it.
Bronc-OH
New York
Jeep XK, Jeep WJ
photo by Mattwings
Look at the size of the window, then picture the glad dropping down into the door. Note the size. The glass isn't square
CrownCityMisfit
CrownCityMisfit
Aaron
Pasadena, CA
Focus, Crosstrek
Well that makes perfect sense thanks.
BroncoPA65
Lehigh Valley, PA
Various Fords & VW's
photo by Mattwings
A little different explanation of it :
Look at where the "front" of the rear fender /wheel well is located... The window overlaps that feature so when the window is lowered it must "tuck in" at the bottom of the door, and therefore needs a notch out of it to go down all the way (like the others said)...
Atomicdog
Eddie
Philadelphia
photo by Mattwings
It's the "Get the 2-door" triangle. 😃
ricstang
Richard
Lincoln, NE
1995 Ford Bronco
Does anyone know the part number? The covering on my "triangle" on on the passenger side is coming apart. Thanks!
