Water in doors from rain?
jackb10
Chicago
2021 Bronco Outer Banks; 2019 Ranger XLT
The last couple heavy rains we had here in Chicago I noticed some water sloshing noises while driving. Ended up my front passenger door had a considerable amount of water in it. There is a drain plug at the bottom of the door that I was able to drain but the next time it rained it had water again. There is no noticeable issue with the weather striping and I do take my doors off regularly but there should not be any water going into the door.
Anyone else come across this? I am bringing it to the dealer to check out...
710-oil-614
Cal
Columbus, Ohio
2023 Maverick Tremor, 2010 Toyota Tacoma
Do you have a hard or a soft top? The soft top pours water on both front doors down the windows and over the door seals. Even the best weather seal subjected to a bunch of water is liable to let some in. If your seal isn't perfect and the rains were heavy it's entirely possible.
rtazz17
Rob
Connecticut
2022 Ford bronco big bend
like inside of the door itself? no I havent had any of that.
SpringTXOR
The Woodlands, tx
1986 Bronco XLT
Little square drain ports on the bottom are clogged. Happens a lot on my F-150.
swami37
Fort Lauderdale Florida
1950 Ford F-1 and 2020 F150 FX4
Ksjrb03
Tx
F250
Actually yes, water will get into the door like every other vehicle. The drain hole you found is there for a reason. Yours has an issue.
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Hi there! Will you send us a message with your VIN and your local Ford dealer? I can look into things on my end.
