- chris
- Jul 29, 2020
- 2
- 3,232
- 9,642
- connecticut
- Mazda
- Base
- Banned
- #1,336
https://www.motorcraftservice.com/AsBuilt/How do I get in on this? Lol
7/20 should already have been built. Don't expect an email. Ford sucks with emailsNo email yet, but should be getting close to built on my Outer Banks. 7/20 build date, 8072
Vin: 1FMDE5AH8MLA68521
So if the modules are showing, what exactly does that mean?Thank you sir
the bronco is pretty much being builtSo if the modules are showing, what exactly does that mean?
Jesus now its back to todays date?My window sticker (bottom) date has gone from 7/22 this morning to 7/19 just now?
Anyone know the significance of that date?
Or is built depending on how long it’s been since they populatedthe bronco is pretty much being built
I had a blend date of 7/19 and 7/20Or is built depending on how long it’s been since they populated
I cannot make any sense of these things. My Sticker date hasn't changed from 7/17 since the weekend so who knows what to make of it?Jesus now its back to todays date?
Are you checking the correct date? The blend date is at the top of the sticker. The date at the bottom is the date the sticker was last updated. Here is my blend date - and the number to the right of that is the rotation number (the sequence of assembly) on the build date.I had a blend date of 7/19 and 7/20
Showed up at the bottom of the sticker. I was a 6/7 then moved to 6/21 now 7/19
Pretty sure it is built then and finishing Quality Check to ship. It may have shipped tooI had a blend date of 7/19 and 7/20
Yes, blend date is at the top 7/19Are you checking the correct date? The blend date is at the top of the sticker. The date at the bottom is the date the sticker was last updated. Here is my blend date - and the number to the right of that is the rotation number (the sequence of assembly) on the build date.
@Ladysailor sorry but @djbuff303 ia correct. Looks like you’ve been looking at the sticker date, not the blend date.Are you checking the correct date? The blend date is at the top of the sticker. The date at the bottom is the date the sticker was last updated. Here is my blend date - and the number to the right of that is the rotation number (the sequence of assembly) on the build date.
OK - you have it correct. If you go to https://www.motorcraftservice.com/AsBuilt and enter your VIN number - you can get to a page that should provide a list of modules. The modules themselves are not important - if they show up, then your Bronco was most certainly built. (as it gets built the modules get registered with the service database).Yes, blend date is at the top 7/19
Bottom date is 7/20
