Will dual tops stop an order from being built?
reschilling
Rob
Fuquay Varina, NC
Does anyone know if dual tops will stop an order from being built?
JohnnyBronco
Pennsylania
X4
2 years ago it did. And I could not even switch to a MIC 1.0 but only delete tge hard top to get it built.
And I thought all hardtops were constrained when the order blanks opened for that single 24 hour period or was it soft
MNBigfoot
MN
The floppy tops have never been a contrant, so it if you were to otherwise order a softtop, it could hold up your order. If you had to have the hardtop, it should make no difference.
reschilling
reschilling
Rob
Fuquay Varina, NC
I like both tops. My logic was is the hard top was $1895 this round of ordering it will be 3x more expensive to buy it after ordering. So for $2495 both tops seemed like the best way to go and leave my options open.
Grumpy
Who's
On a Lake
22 2dr
I would leave the order as is, both tops. The worst that could happen is Ford says one or the other later. But don't change it.
Landin536
GA
VW Golf
The hardtop has always been constrained. The value of the dual top option is just too good to pass up. I absolutely love and pull back my soft top whenever I can, but I’d be lying if I didn’t admit that in the winter months I wish I had the hard top. It’s such a clean look on the Bronco.
Ford Bronco Will dual tops stop an order from being built? 3EEF97B0-C2AA-4885-AC8F-B8154E4B4BD2
JTA
VA
Toyota Sequoia
Mine was just built on 4/11 with both tops.
T|K
Raleigh, NC
Bronco hopeful
ours was built on 4/5 with dual tops also. It was the cheapest way to get both so we went with it.
Roll Tide!
Robert
SW Florida
4 Door Carbonized Gray Wildtrak
Does the dual top option come with the factory soft top or with the Bestop Trektop?
