Windshield washer fluid leak
Wharton5
Washington
22 Bronco Sasquatch
New here, but wanted to post about an issue I had with my 22 Bronco. I had a low washer fluid light come in and checked a couple forums including this one. Most talked about a leak under the tank, and under the cowling, and also with the full tube. After pulling the front passenger tire, the fender liner, and finding nothing, I refilled the tank and tried again. Front worked. Nothing out the back. I went to the cargo area and found that the carpet was damp. I started with the driver side and chased the hose to the passenger side, and found the leak. Reconnected and added a zip tie for good measure. Hoping this helps the next person. Pictures show progress and location.
Ford Bronco Windshield washer fluid leak IMG_3795
Ford Bronco Windshield washer fluid leak IMG_3796
Ford Bronco Windshield washer fluid leak IMG_3797
4X4XFAR
PA
F250, GT500
I had exactly the same issue with my 2-door 2022 Base last week. I also tracked it down myself to save the hassle at the dealership.
Wharton5
Wharton5
Washington
22 Bronco Sasquatch
Yeah, I was wondering what this would have cost had I taken it in to them to fix!
JawnyBronco
DelMarPa
2023 Bronco 4dr
Wonder if I’ve found a similar issue… just noticed what seems like water dripping from the bottom of where the tranny mates to the t-case. Tried my windshield washer today and nothing came out, empty…
lakesinai
Charleston SC
I just had my tank with "split seam" replaced by dealer at 75 000 miles. M2DZ17618B Part is $381.82 and .6 hours. Cost me $100 deductable under Ford Protect warranty.
