Pennsylvania WTB Oem subwoofer speaker
pizzy
larry
Pa
2023 bronco base
I have a base bronco that came with out the functioning subwoofer. Does anyone have the subwoofer speaker that they removed when upgrading? im intereted in buying one to try and get the original sytem working the way it was supposed to. Alternatively does anyone know the part number of that speaker? maybe i can buy it new
Fly by Nite
Walt
Pa
You'll need to buy a functioning amp too. They're about $75 on eBay.
https://www.ebay.com/itm/3550614486...-b32f-d661d2115c05|iid:1|vlpname:vlp_homepage
For the speaker, the Kicker is a popular choice:
https://www.crutchfield.com/p_20648CT674/Kicker-48CWRT674.html?omnews=18446213
After you've installed the amp and speaker, you need to turn them on using a laptop with the Forscan programming.
There are a bunch of threads on upgrading the 2023 'sub-delete' package, here's a good one:
https://www.bronco6g.com/forum/thre...-mandatory-and-functional-amps-removed.61106/
pizzy
pizzy
larry
Pa
2023 bronco base
Thanks for the info..Yes im aware of whats needed for the complete restore .. I did just as you said i already ordered the amp from ebay and have used forscan for several changes to the bronco already, so im pretty sure with whats needed there. I really just wanted to see how it sounds with the factory speakers exactly as the engineers meant it to be. My days of big subs and component speaker sets are over and i just wanted to add a little more thump to the bronco
