ZROADZ Modular Bumper Fog Light Kits
ZROADZOFFICIAL
ZROADZ
Corona
2022 Ford Bronco
Ford Bronco ZROADZ Modular Bumper Fog Light Kits Untitled-6
ZROADZ Front Bumper LED Mounts and kits are a quick and easy way to add forward-facing lighting to your vehicle. The simple bolt-on installation uses factory bolt locations and provides significant auxiliary lighting. Typical installation time is under 30 minutes and can be successfully installed using common hand tools by even the most casual enthusiast. ZROADZ Front Bumper LED Mounts are available in complete kits with light and wiring harnesses, or as brackets only for mounting common and popular LED light bars. ZROADZ Front Bumper LED Mounts are designed and made in USA.
Features & Benefits:
  • Front Bumper OEM Fog LED Kit with White and Amber Pod Lights
  • Sold as a complete kit, Includes: (4) 3 Inch White ZROADZ LED Pod Lights, (2) 3 Inch Amber ZROADZ LED Pod Lights, mounting brackets, wiring harness with the fusible link, relay, toggle switch, all necessary hardware
  • 1712 Lumens, 20 Watts, CREE 5W LED Chips per pod light
  • Flood Beam, IP68 and IP69K Protection Rating, 50000 Hour Life Span
  • Mild Steel
  • Easy, bolt-on installation, no drilling required
  • Low-gloss textured finish
  • Limited lifetime product warranty, 3-year warranty on the finish
  • Manufactured by ZROADZ Off-Road Products in Corona, California. Made in the USA
  • Kit includes (1) Dual universal wiring harnesses and (1) splitter harness
  • Also available as bracket only, see part number Z325401 or with white pods Z325401-KIT, or amber pods Z325401-KITA
  • Fits Heavy Duty Modular Bumper Models Only
Front Bumper Fog LED KIT, Includes (2) 3 inch ZROADZ Amber LED Pod Lights and (4) 3 inch White LED Pod Lights - Part # Z325401-KITAW
Ford Bronco Front Bumper Fog LED KIT, Includes (6) 3-inch ZROADZ Amber LED Pod Lights - Part # Z325401-KITA
Front Bumper Fog LED KIT, Includes (6) 3-Inch ZROADZ White LED Pod Lights - Part # Z325401-KIT
Ford Bronco ZROADZ Modular Bumper Fog Light Kits customtruckaccessories (2)
Ford Bronco ZROADZ Modular Bumper Fog Light Kits customtruckaccessories (3)
Ford Bronco ZROADZ Modular Bumper Fog Light Kits littlemule21 bronco (5)
Ford Bronco ZROADZ Modular Bumper Fog Light Kits littlemule21 bronco (6)
Ford Bronco ZROADZ Modular Bumper Fog Light Kits littlemule21 bronco (8)
Ford Bronco ZROADZ Modular Bumper Fog Light Kits littlemule21 bronco (4)
Ford Bronco ZROADZ Modular Bumper Fog Light Kits mamas_stallion img4
adamruiz2001
SoCal
Ford SVT Lightning
Are your guys amber lights SAE compliant? or for offroad use only? thanks
