Adaptive learning in a MANUAL transmission.
philagust
Phil
Does anyone know if it’s possible to have an ‘adaptive learning’ manual transmission that can be ‘reset’ in a similar fashion as a manual transmission?
On the bronco, clearly.
thanks
philagust
Phil
Correction: in a similar fashion as an AUTOMATIC transmission.
Boreal
Colby
MB
www.cspencephoto.com
2022 Badlands 2DR
You control the shift points... what can a manual transmission learn? Its you that needs to change how you drive.
As far as Rev Matching goes, that should be bang on every time since its a calculated and known rpm...
Im not to sure what else you could be asking here. GOAT modes are mostly fuel, boost and throttle mapping... the ECM will learn, trim and adjust what it needs to to run healthy and safely...
philagust
Phil
I had a service tech try and tell me they ‘reset’ the adaptive learning on the manual transmission.
I asked for an explanation being that manual means, well, just that, by hand. It can’t learn anything.
The services advisor insisted it was reset and that it’s a thing. I don’t buy it for a second, which is why I’m looking for an expert answers on the matter.
BLTN
Colowado
'23 Badlands; '95 Jeep XJ; '05 F-350; '07 Camry
You're right - Both of them are jerking your chain or don't know what they are doing - Best thing is to find a new service provider.
Manual trans has few, if any, sensors - Oil temp, gear position, if you're lucky....they just don't need them. YOU are the "adaptive learner".
