- Rick
- Mar 24, 2021
- 17
- 1,136
- 1,827
- Lincoln Ca.
- Nissan Frontier 4WD
- Base
I did all this too. But with Kicker speakers And now it sounds better, with all of your settings@RagnarKon, or others...can you please verify something for me?
1. Added Focal 6.5 Speakers in kick panels and tweeters in the dash.
2. Added SSV Pods in the rear with 6.5 Focal Performance Coaxial.
No amp, no sub yet. Factor amp and sub are non-functional. When I made these changes, it seems like there is less power than the settings for the 4 inch speakers...
EQ Settings - ACM 727-01-02 CHANGED
Speaker Configuration Settings - ACM 727-01-01
- xxYY-xxxx-xxxx
- 00 = EQ Off
- 01 = EQ On (High-pass filter on the rear pods)
- xxYx-xxxx-xxxx - Driver Front Kick Panel/Dash Speakers LEFT ALONE
- 0 - Speaker
- 1 - Tweeter
- 2 - Speaker & Tweeter
- 3 - No Speaker (ACM disable)
- xxxY-xxxx-xxxx - Passenger Front Kick Panel/Dash Speakers LEFT ALONE
- 3 - Speaker
- 7 - Tweeter
- B - Speaker & Tweeter
- F - No Speaker
- xxxx-Yxxx-xxxx - Passenger Rear Pod Speaker CHANGED
- 0 - Speaker
- 1 - Tweeter
- 3 - No Speaker
- xxxx-xYxx-xxxx - Driver Rear Pod Speaker & Subwoofer CHANGED
- 0 - Speaker
- 2 - Speaker & Sub
- 4 - Tweeter
- 6 - Tweeter & Sub
- 8 - Speaker & Tweeter
- A - Speaker, Tweeter, & Sub
- C - No speaker
- E - Sub only
but now I want to hook up a 10 inch power sub down firing woofer do I hook it to the speaker outputs on the 200 kicker key?
And does it matter if I hook it to the door speaker outputs or the rear pods now, if the EQS off?
