No he didnt, but hes assuming you might need to. I would assume that as well. Unless you want to try and run 40psi of boost...lolY
You changed your turbos out for the 400whp? And is that necessary for the 2.3?
Oof. Sadness.No he didnt, but hes assuming you might need to. I would assume that as well. Unless you want to try and run 40psi of boost...lol
Sequential turbo 2.3L!!!No he didnt, but hes assuming you might need to. I would assume that as well. Unless you want to try and run 40psi of boost...lol
Built block 2.3ās with big turbos can go well north of 700 WHP. I think on the stock block you can do 450 WHP safely, but donāt quote me on that. Itās a super capable motor, especially with all the aftermarket for them.Oof. Sadness.
If I understood @BadmansSAS correctly he was wondering how much gain would be from tune&fuel only with no hardware changes. I am wondering the same. My guess is the very vast majority. Thoughts @MWILD ?Hard to say for sure, but if you look at similar Sasquatch 2.7L Broncos on a Dyno Jet they pull between 250-260 WHP and 320-340 WTQ. Like @2020FordRaptor said, I would at least install an aftermarket IC. CV Fab has them for under $600 shipped.I bet it flies man. I'd be up for this, but I would want to keep mine mechanically stock. Just a full E85 tune. I wonder how much the mods helped over what it would do just straight up stock? Also you can enable the ARF gauge in forscan under the IPM controller I think is where it is.
Yikes, Iām reading that back and now realizing that I didnāt give any sort of answerIf I understood @BadmansSAS correctly he was wondering how much gain would be from tune&fuel only with no hardware changes. I am wondering the same. My guess is the very vast majority. Thoughts @MWILD ?
Realistically its the octane that E85 offers that allows tuners to really add timing in, and much more agressively as well. But the honest truth is you really dont need to run full E85 to get the full benefit of e85. You really will get all the benefits from say e50ish vs full E85. The only difference is its 10x easier to just pump in straight up e85 from the pump rather than trying to blend it with 93 pump gas to reach that e50 number. But really, e50 is where the octane gains allowing more timing really end.Very nice. Those are good gains. I am surprised not surprised how much e85 added.
I wonder where I would end up as I have the charge pipes and downpipes. Plus all the other mods you have. The only mod I am waiting on now is the intercooler, as I want to get the Injen one.
Ken-Bob Block seems to get good use outta the 2.3L...or izzat the 1.6L?!?Built block 2.3ās with big turbos can go well north of 700 WHP. I think on the stock block you can do 450 WHP safely, but donāt quote me on that. Itās a super capable motor, especially with all the aftermarket for them.
rock on brotherHello friends,
Wanted to share my recent dyno results. I spent a lot of time making sure we got numbers with the stock calibration, ZFG 93 tune, and their E85 tune. We had to drain the tank and use a custom tune to allow the fuel pump to run so we could swap to E85. The 2.7L Ecoboost can run full E85 with the ZFG Racing custom tune without the need for a HPFP.
Big thanks to Adam @ZFGracing
Here's a breakdown of the mods that are installed on my Bronco.
2022 Ford Bronco Big Bend Sasquatch 2.7L
List of performance mods:
- HP Tuners MPVI3 w/ ZFG Racing Custom Tune
- CV Fabrication Intercooler
- CV Fabrication 3" Cat back Exhaust
- Injen Evolution Cold Air Intake System - EVO9301
- Turbosmart Kompact EM VR19 Dual port BOV
- NGK 95605 plugs gapped to .028
- BMS Pedal Tuner
So basically, Intake, exhaust, Intercooler and tune.
I will go back to the dyno after I add Down-pipes and charge-pipes.
Here are the results:
- Stock calibration w/93 Octane
- ZFG Racing 93 Tune
- ZFG Racing E85 Tune
Here's a video of the runs:
With the E85 tune:
- 0-60 in 4.3s
- 1/4 mile in 12.9s
- (Via Dragy)
Dude, that's gnarly. 400 WHP is more than the Raptor is bringing to the table. I swear, I am beyond tempted to do this, even though I have absolutely no need for that much power in my Bronco.Hello friends,
- BMS Pedal Tuner
With the E85 tune:
- 0-60 in 4.3s
- 1/4 mile in 12.9s
- (Via Dragy)
Thanks!Dude, that's gnarly. 400 WHP is more than the Raptor is bringing to the table. I swear, I am beyond tempted to do this, even though I have absolutely no need for that much power in my Bronco.
Well done.
