- Chuck
- Apr 17, 2021
- 20
- 343
- 390
- Phoenix
- Website
- azbluey.com
- 2.7L Badlands NS 4dr
- Badlands
I know there's those little adapters that have USB-B and C on them you just plug in... but I'd rather just replace that outlet with something like this one: https://www.amazon.com/Charger-Waterproof-Delivery-Voltmeter-Motorcycle/dp/B07NV9D61R/
EDIT: I’ve installed this and it wasn’t difficult at all; honestly the hardest part was getting old socket out.
Back of center console just pull and two top and two bottom tabs let go easily with no tools.
For me green wire was hot but double check with a voltage tester before you wire it up. Also there’s a tab underneath the backside of the old socket to let loose the wire adapter. The actual socket itself I sort of brute forced out forward into the console. Other one pushes in and screw locknut goes on back. Use a long skinny flathead to tighten it up.
Some pics of the install.
