Status
Not open for further replies.
tomsoffroad76
TOMS
Medford, Oregon
2022 Ford Bronco
🚨 New Product Release: Billet Upper Control Arms for 2021-2024 Ford Bronco 🚨
TOMS OFFROAD is excited to announce the launch of our new Billet Upper Control Arms for the 2021-2024 Ford Bronco! If you're looking to improve your Bronco’s off-road capabilities, enhance suspension performance, and upgrade its durability, these billet control arms are the perfect solution.
Key Features
  • - Precision CNC Machined Billet Aluminum**: Built tough to withstand the most demanding off-road conditions.
  • - Improved Suspension Articulation**: Enhanced travel and articulation help tackle rough terrain while keeping your Bronco's ride smooth.
  • - Heavy-Duty Ball Joints Engineered for durability and long-lasting performance under heavy use.
  • - Designed for Lifted Broncos**: Perfect for those who have installed lift kits and want to ensure proper suspension geometry and alignment.
  • - Maintenance-Free Bushings: High-quality bushings are designed to last without the need for constant maintenance.
Why Choose Billet Upper Control Arms?
These billet arms are not only stronger than the factory components but are also specifically engineered to deliver superior performance when your Bronco is lifted and used for off-road adventures. Whether you’re navigating rocky trails or handling steep climbs, you’ll notice the difference in control and stability.
👉 Order now: TOMS OFFROAD Upper Billet Control Arms
Ford Bronco NEW RELEASE: Billet Upper Control Arms for 21+ Bronco $1199 from Toms Offroad 660156980-01
Saltwater Junkie
Sir Fishin
Tar Bay,Va.
99 7.3 F350, 22 7.3 F350,25 2.7 BADLANDS SAS
tomsoffroad76
tomsoffroad76
TOMS
Medford, Oregon
2022 Ford Bronco
Much appreciated! Fixed in the post as well!
telenerd
Laramie
Subaru
Howdy. Love the maintenance free ball joints. So what type of lift are these designed for? Looks like they aren’t adjustable for caster? Will an alignment shop just need to tweak the stock caster adjustments?
tomsoffroad76
tomsoffroad76
TOMS
Medford, Oregon
2022 Ford Bronco
Our shop Bronco is on a 3" lift and Radflo coilovers and 37"s. We are dialed in perfectly. Stock adjustments worked great.
Chvless956c
SC
23 Wildtrack
not much info on these. is there built in caster? is there a limitation on wheel backspacing/offset?
Mirage
Huntsville, Alabama
'23 2Dr BL SAS Green/White, '24 2Dr HEL Yellowstone
Key Features
Unsure if these are any better than the ones I have from @Metalcloak but I do like the fact that yalls UCA's have grease fittings! The MC ones I have occasionally squeak when turning, which drives me crazy! I have to spray some lithium grease on them from time to time, but it kills the squeaking for a little while.
Is there any benefit of your arms, if I'm in a 3"-4" total lift with the Sasquatch package?
tomsoffroad76
tomsoffroad76
TOMS
Medford, Oregon
2022 Ford Bronco
They are optimized for a with a 3” lift, but work well well from 2”-4” of lift. We are working on wheel fitment. We’ve had a few different wheel and tire combos and haven’t had any issues thus far. More info coming soon.
tomsoffroad76
tomsoffroad76
TOMS
Medford, Oregon
2022 Ford Bronco
They are dialed in for that amount of lift, with great serviceability. They won’t have to be rebuilt every 10-15k like many other arms on the market. Stock like NVH, with full floating performance.
BigMeatsBronco
Allan
2021 FE 2 door
will these be available for the Braptor?
tomsoffroad76
tomsoffroad76
TOMS
Medford, Oregon
2022 Ford Bronco
Status
