Fast Intentions Inc.
Fast Intentions
Simi Valley, CA
www.fastintentions.com
2021 Bronco 2.7L
Fast Intentions has released a mount to install an Apex Designs compact air reel in the 6G Bronco (4-Door) / Bronco Raptor with hard top & soft top roof.
Our mount affixes to the driver side roll bar in factory mounting location. The mount is "direct fit" without cutting, drilling, or welding to install, as we use the thread boss that is pre-installed in most Bronco roll bars. We recommend that you confirm that your Bronco has the factory threaded Nutserts on your roll bar prior to ordering. We have designed our mount to fit with the Bronco Raptor rear roll bar cross brace, as well as the Diabolical Inc. slipstream security enclosure.
Bronco Apex Air Reel Mount by Fast Intentions : In-Stock & Ready to Ship
  • CNC Laser Cut from 11ga 304 Stainless Steel.
  • CNC formed specifically for 6G Bronco.
  • Fits Bronco 4 Door and Bronco Raptor.
  • Fits with Diabolical Inc. Slipsteam Security Enclosure.
  • No cutting or drilling required for installation.
  • Includes M8 mounting hardware.
  • NOT compatible on Bronco 2 Door.
  • Apex Designs Compact Air Reel System is sold separately.
Ford Bronco NEW PRODUCT!  APEX Designs Compact Air Reel System Mount by Fast Intentions apex_1
Ford Bronco NEW PRODUCT!  APEX Designs Compact Air Reel System Mount by Fast Intentions apex_2
Ford Bronco NEW PRODUCT!  APEX Designs Compact Air Reel System Mount by Fast Intentions apex_3
Ford Bronco NEW PRODUCT!  APEX Designs Compact Air Reel System Mount by Fast Intentions apex_4
Ford Bronco NEW PRODUCT!  APEX Designs Compact Air Reel System Mount by Fast Intentions apex_5
Ford Bronco NEW PRODUCT!  APEX Designs Compact Air Reel System Mount by Fast Intentions apex_8
Ford Bronco NEW PRODUCT!  APEX Designs Compact Air Reel System Mount by Fast Intentions apex_9
Ford Bronco NEW PRODUCT!  APEX Designs Compact Air Reel System Mount by Fast Intentions apex_10
Ford Bronco NEW PRODUCT!  APEX Designs Compact Air Reel System Mount by Fast Intentions apex_11
For those who already have an under the hood mounted compressor, we are working on a "pass through" bulkhead to get through the firewall along with an airline kit to run your on-board air system to the Apex air reel at the rear of your Bronco. Stay tuned for more details!
Ford Bronco NEW PRODUCT!  APEX Designs Compact Air Reel System Mount by Fast Intentions apex_6
Ford Bronco NEW PRODUCT!  APEX Designs Compact Air Reel System Mount by Fast Intentions apex_7
UPDATE: 10/22/2024
Good news! We have confirmed fit of our Apex Air Reel Mount with the 4-door soft top roof.
The linkage for the soft top is very close to the Apex low profile banjo fitting, however you can still hinge the top to allow access into the trunk space.
Warning: You will not be able to fold the soft top all the way down to "convertible mode" as the linkage will hit the air fitting.
Ford Bronco NEW PRODUCT!  APEX Designs Compact Air Reel System Mount by Fast Intentions apex_14
Ford Bronco NEW PRODUCT!  APEX Designs Compact Air Reel System Mount by Fast Intentions apex_15
Ford Bronco NEW PRODUCT!  APEX Designs Compact Air Reel System Mount by Fast Intentions apex_16
Ford Bronco NEW PRODUCT!  APEX Designs Compact Air Reel System Mount by Fast Intentions apex_17
Bigmoose
Jon
RI
2019 Flex Ecoboost Limited
Any plans for a passenger side mount? My power tank is on that side.
ElDuderino
Ohio
23' Badlands
Fast Intentions has released a mount to install an Apex Designs compact air reel in the 6G Bronco (4-Door) / Bronco Raptor.
Our mount affixes to the driver side roll bar in factory mounting location. The mount is "direct fit" without cutting, drilling, or welding to install, as we use the thread boss that is pre-installed in your Bronco roll bars. We have confirmed fit with the Bronco Raptor rear cross brace, as well as the Diabolical Inc. slipstream security enclosure.
  • Apex Designs Compact Air Reel System is NOT included.
Are there any plans to make this for the 2 door at all?
Hellish
Leenie
Tucson
02 Wrangler Sahara, 22 OBX nonSquatch, 24 Heritage
Feeling like a bastid stepchild in my 2 door...
TNcoupe
Decatur,TN
2022 Badlands, 2023 BD, 1969 F100, 1955 T Bird
Spyder625
NJ
Caddy V, INEOS Grenadier
will there be a bracket made for the raptor as the back is different from the stiffening bar to mount that reel? Great work
vrtical
Doug AI
GSMNP, TN
Fords
this will work, uses the existing mounting holes and its below the C brace.
Noremac
East Coast Florida
2021 Bronco Badlands Sasquatch
Careful, not all broncos have the nutserts on the rollbars.
Fast Intentions
Simi Valley, CA
2021 Bronco 2.7L
2-door Bronco owners that go off-road, air down, and want something like your product:
We have been since June 13, 2020.
I've been wanting this reel, a mount for the 2 door or a molle panel would be 🔥
Don't worry, we haven't forgotten about the 2-door crowd. We are examining design options for the 2-door Bronco now and we are hoping to have an option for you soon.
It would be great if we could get a preliminary list of 2-door Bronco customers that would be interested in something like this. This will help us gauge interest in the product and account for initial production run quantities.
Fast Intentions
Simi Valley, CA
2021 Bronco 2.7L
Definitely interested when you get the ‘pass through’ rolling. I already have mine mounted under the hood, but I love that air reel. Nice work!
Thanks! Stay tuned!
You might be onto something here. We will have to look at this.
Yes, our mount is confirmed to fit with the Raptor rear stiffening bar. Our air reel mount will fit without removal of your stiffening cross bar.
Appreciate you mentioning this important detail. Some of the early model Broncos did not come with the Nutserts pre-installed from Ford. We recommend that you confirm that your Bronco has the factory threaded Nutserts on roll bar prior to ordering.
Spyder625
NJ
Thanks! Stay tuned!
thank you!
