2.5 in spacer lift (front & rear) w/ 33 in tires??
Broncojb
Jake
2022 Ford Bronco
Im looking to level out my 2022 Bronco Black Diamond with a 2.5 inch spacer lift kit. (Front and rear lift)
Right now I have 33 inch A/T tires. I'm trying to budget for 35's. Has anyone installed a 2.5 lift with 33's?? Does it look ok?
Thank you!
swami37
Fort Lauderdale Florida
1950 Ford F-1 and 2020 F150 FX4
Here is mine with spacers and 33s
Before I went bigger.
I now have Nitto 35s and SAS wheels
Ford Bronco 2.5 in spacer lift (front & rear) w/ 33 in tires?? 59DD136A-D506-4ABD-9B4F-71895C9050AF
indio22
Chicagoland, USA
Thank you!
2.5" lift is too high visually for 33" tires in my opinion. Makes the tires look too small, not filling up the wheel openings enough. Even with 35" tires it can be a bit high.
Consider a Sas with 35" tires is just over 1" higher than your Black Diamond. So 2.5" is going to put it up near double that.
I have 35" tires on my stock 2-door base with no issue - on pavement. Planning to bump the rear up 1" and the front around 1.75" with some spacers for off-road.
Rkgzx9leftcoast
Robert
Scottsdale AZ
Jeep JL
Might consider Sasquatch Takeoff suspension and wheels and tires if you like them? Can find deals on them. Will work better that a spacer -puck style lift.
ABorges
Art
Fresno CA
1973 F100
Thank you!
33s will fit without a lift, you might have to remove the crash bars. You can lift it when you get the 35s.
Parthebar
Sean
2022Bigbend!
2022 Bronco Big Bend
Did 2" spacers with SAS 35" tires no issues. Full matte wrap, replace BB grill incl 3 yellow lights, Bronco chrome script letters, blacked out windshield (when top up, top half is all black), Kicker 200.1 amo, 4" kickers, SSV 6.5" rears - sound is awesome w/top off. Could use a little more base, but good for now. Thoughts on build?
