- Joel
- Apr 7, 2021
- 295
- 715
- 1,298
- Arizona
- Website
- www.stage3motorsports.com
- 2021 Bronco Badlands 4 Door 2.7L Ecoboost
- Badlands
2021-2022 Bronco ARB Zenith Bumper for Narrow Flare Models ARB3280020
2021-2022 Bronco ARB Zenith Bumper for Narrow Flare Models Features:
The 2021-2022 Bronco ARB Zenith Bumper for Narrow Flare Models is designed as a full bumper replacement with the four-wheel driver in mind. Not only is it aesthetically pleasing, but has premium off-road protection and functionality. It provides much needed protection for the front of your new 2021-2022 Ford Bronco. The durable, steel construction means premium protection for your front bumper. It also accommodates adaptive cruise control and parking sensors while adding off-road essentials such as an integrated LED lightbar, twin jack points, and rated recovery points. Be confident that this bumper will not quit on you even when you push it to its limits. Morning, noon, and night, you will always have the advantage with the 2021-2022 Bronco ARB Zenith Bumper for Narrow Flare Models .
Mounts the Compatible Winch in a Feet Down Orientation
The 2021-2022 Bronco ARB Zenith Bumper for Narrow Flare Models is equipped with two reinforced high lift jacking points fitted to the center pan and is perfect for use with the ARB Jack. There are also pre-installed, twin-forged, chassis-mounted recovery points that are ARB rated to 8T in a direction of pull up to the the maximum turn angle of the front wheels and are suitable for traditional 4.75T rated bow shackles or the ARB Soft Shackle. Adaptive cruise control, fog light compatibility, and parking sensors are included for greater driving assistance. Best of all, the 2021-2022 Bronco ARB Zenith Bumper for Narrow Flare Models is crafted from durable steel and coated with with a beautiful Integrit™ black, textured powder coat finish that is protected with an undercoat EDP20 Ecoat and zinc primer for corrosion resistance.
Fitment:
For Narrow Flare Broncos Only, link to wide version: 21-22 Bronco ARB Zenith Bumper for Wide Flare Models
Does Not Fit Ford Bronco Sport
- Vehicle-specific design suits the Ford Bronco narrow fender flares
- Durable, steel construction for maximum protection
- Pre-assembled with fog housing and integrated LED light bar
- Twin jack points located in center pan
- Twin-forged chassis-mounted ARB Rated 8T recovery points
- Wing design allows for a 37-inch tire (suitable suspension lift and rim off set required)
- Press formed apertures in bumper for fitment of fog light surround OE LED fog lights
- 3mm laser cut and press formed center panel with NP provision in vintage silver
- Does Not Fit Bronco Sport
Fitment:
- 2021-2022 2-Door Ford Bronco
- 2021-2022 4-Door Ford Bronco
