2021-22 FORD BRONCO | FENDER FLARE DELETES
DV8offroad
Riverside, California
dv8offroad.com
Bronco's & Jeep's
Hey guys we just released our Fender Flare Delete Kit this morning!
DV8 Offroad has designed fender flare deletes for the 2021+ Bronco in order to eliminate factory flares & maximize tire clearance. Removing your fender flares increases your distance to obstacles like trees & boulders on the sides of the trail, enabling you to fit in tighter spaces off-road. Having removed the flares, you’re left with unsightly holes and unfinished body panel edges. These Bronco fender deletes clean up those unfinished areas and imbue a more aggressive stance to your ride.
You can find them here: https://dv8offroad.com/products/bronco-fender-flare-deletes
Ford Bronco 2021-22 FORD BRONCO | FENDER FLARE DELETES _DSC5945-Edit
Ford Bronco 2021-22 FORD BRONCO | FENDER FLARE DELETES DSC05634-Edit
Ford Bronco 2021-22 FORD BRONCO | FENDER FLARE DELETES DSC05594-Edit
Ford Bronco 2021-22 FORD BRONCO | FENDER FLARE DELETES DSC05598-Edit
Key Features:
  • Set of 4 Front & Rear Fender Deletes
  • Cleans Up Fender Panels After Flare Removal
  • Laser-Cut 4mm Steel
  • Micro-Texture Black Powder Coat Finish
  • Paintable Aluminum DV8 Accent Plate
*** Note: Our Bronco Fender Deletes fit all 4-Door Bronco trim levels. These will not fit the 2-Door models.
Visit https://dv8offroad.com/pages/ford-bronco-bumpers-and-accessories to shop all of our Ford Bronco Parts and Accessories.
Plus... use code "ForumMember" at checkout for 10% off!
604Bronco
British Columbia
www.bronco6g.com
To each their own, but I'm not a fan of this much "poke." Plus your paint on the side of the Bronco is going to hate you.
Ford Bronco 2021-22 FORD BRONCO | FENDER FLARE DELETES 1649783543508
BC overlanding
IN/KY area
$350 for 4 strips of formed metal :oops: Bronco pricing is out of control
helifino16
Ron
Mount Sinai, NY (Long Island)
@DV8offroad
It's a shame that these were not made to be easily removed. Some states require more tire coverage for street use, so it would be nice to throw these on for trail use, then return the factory Fender Flares for daily use. It looks like reversing the install is not complicated, but not trivially easy either. A nice looking solution, though.
mattymik
Matt
Houston, TX
2019 Honda Odyssey, 2023 WildTrak
PSA: if anyone is planning to do this and has base/BD/BB/BL flares, I would likely buy those from you if shipping/price makes sense. Please send me a PM.
That mitigates your cost for sure!
