- First Name
- Joel
- Joined
- Apr 7, 2021
- Threads
- 295
- Messages
- 715
- Reaction score
- 1,298
- Location
- Arizona
- Website
- www.stage3motorsports.com
- Vehicle(s)
- 2021 Bronco Badlands 4 Door 2.7L Ecoboost
- Your Bronco Model
- Badlands
- Thread starter
- #1
Turn your factory tow hooks into a traditional shackle mount with this new conversion kit from Rough Country.
These are in stock and shipping.
2021 Bronco Rough Country Tow Hook to Shackle Conversion Kit RS171
2021 Bronco Rough Country Shackle Conversion Features:
While the stock tow hooks on the 2021 Broncos can make for handy recovery points for both you or your buddy's Wrangler, but the stock tow loops aren't the most adaptable things when it comes to using recovery ropes, winches, and other recovery gear. The Rough Country Tow Hook to Shackle Conversion gives you a ton more options for getting yourself or your friends out of tough jambs out on the trail. The Rough Country Bronco Tow Hook Shackle Conversion replaces your Bronco's stock tow hooks with a pair of clevis mounts capable of accepting 3/4" D-Rings and pushes them farther out from your Bronco's frame so that they're more accessible and easier to use when you're doing off-road recovery operations. The Tow Hook Shackle Conversion easily bolts on in place of your Bronco's stock tow hooks and allows you to use just about and D-ring or recovery shackle that you need to get you or your friends out of trouble out in the bush. Extremely Durable Steel Construction with Black Powder Coat Finish and Drop-In Install
The Rough Country Bronco Shackle Conversion Kit comes with a pair of shackle mounts that are made using high-quality materials so that they don't let you down when you're off the beaten path. Each mount is made entirely out of heavy-duty steel and comes topped off with a textured black powder coat finish that keeps them protected from corrosion in practically any climate or application. The Shackle Conversion mounts feature an angular design with laser-cut "RC" lettering and lightening cuts that give them a great look. The Shackle Conversion Kit is compatible with the factory front bumpers and stock skid plates, making them an easy and hassle-free way to improve your Bronco's recovery options. Rough Country's brackets install directly to your Bronco's frame using the mounting points for the stock tow hooks, and they come with all their necessary installation hardware and instructions.
Fitment:
Will not fit Bronco Sport: this shackle conversion will not fit Bronco Sport models.
May not fit aftermarket bumpers or skid plates: this kit may not fit with aftermarket front bumpers or aftermarket skid plates.
- Turns your Bronco's tow hooks into 3/4" shackle mounts
- Improves your Bronco's recovery tool options
- Installs right into place of your Bronco's tow hooks
- Steel construction with black powder coat finish
- Compatible with stock bumpers and skid plates
- Straightforward, bolt-on installation
- Will only fit Broncos with stock tow hooks
- Will not fit Bronco Sports
Fitment:
- 2021 Bronco 4-Door
- 2021 Bronco 2-Door
