2023 Raptor will not start
Fishwrinkle
12 GC overland 5.7, 18 GC srt 6.4
If you take it to the dealer then make sure all aux accessories are not hooked up. Dealer will immediately tell you it’s your fault with the stuff you put on.
Rickc/7c/8
Rick
Indiana
Ford F-150
Thanks for all of the reply’s. I will let you know if it happens again.
Wenda morlan
Jill
Missouri
My 2023 raptor has 3000 miles and this has happened twice. Dealer replaced battery last week. Will see how it goes
My new 2023 raptor has had dead battery replaced twice in less than 6 months. I checked the battery monitor 3 days ago as I just found out where it is. It has been losing voltage very slowly for last 3 days . Is there a recall or any info out there on why this is happening.
Rickc/7c/8
Rick
Indiana
Ford F-150
I believe someone said that there is a problem with some of the batteries and they have had them replace under warranty
stdevore
Suzanne
MT
Almost no viltage was showing up on meter.
Yesterday, my remote start wouldn't work. Message said battery was low (my Braptor is 2 months old). Voltage is holding at 9v. Charged it all night with the noco genius. We shall see. Ridiculous that it is even low!
2022 Raptor
Well this has happened 4 times now. Dealer has had it the past 2 days and cannot find anything wrong. I get it back and it is dead the next morning. Tech says Ford knows about problems with Raptors and draining battery when connected to Fordpass app. I deleted vehicle from my app and will see if that works. Sucks not being able to use app to remote start.
pillar406
Javier
www.keeseemotorcompany.com
2024 Bronco
It honestly depends on how long it took to get your Bronco. I work at a dealership and we always test the battery. There was about a 2 year window where most batteries came in and had to be replaced. It was mostly from them sitting for long periods of time and not being run. Anytime I do a PDI if the battery is 12V or lower I throw a tester on it and most of the times I end up replacing them.
