- Adam
- Aug 30, 2021
- 549
- 6,142
- 7,043
- Lindenhurst, NY
- Website
- www.4x4TruckLEDs.com
- 2018 Raptor & 2021 Bronco Outer Banks
- Outer Banks
Giveaway has ended!
Joel.Calc won the double rod holder and Broncobabe221 won the single rod holder.
We're going to be giving away a FREE Fishing Rod Holder Kit from KR Off-Road.
Rules are simple! Post a photo of your Bronco with your fishing pole resting against it and you are entered!
We'll choose one random winner on Friday, May 13th at 5pm (EST) who will win a Double Rod Holder Kit from KR Off-Road.
We'll also choose a runner-up who will win a Single Rod Holder Kit from KR Off-Road.
Your kit will ship once we finish production on these (ETA: June 3rd)
https://www.4x4truckleds.com/kr-off-road-fishing-rod-holder-for-2021-ford-bronco/
If you're a fisherman looking for a place to mount your fishing poles, look no further! Designed here on Long Island, NY (surf fishing capital of the world) this mounting system provides a simple and elegant solution to a common problem. That problem... Where do you mount your fishing poles on the Bronco?
Utilizing the existing mounting points on the front of the truck our stainless steel bracket system provides a secure and stable system to support 1 or 2 rods (per side). Each holder is designed to safely and securely hold your fishing pole without damaging it. The built in angle of the mounting system allows you to transport long fishing rods without the fear of snagging an over-pass or electrical line. The rods sit at an angle hovering over the roof line.
Simply bolt on the system, slide in your fishing pole and head to your favorite fishing spot.
The single kit allows you to install the fishing rod holder on either the driver side or passenger side. You have the option to install the system on the outside or inside as well. Keep in mind that installation on the inside of the factory limb risers will prohibit the hood from opening with the system installed.
The double kit includes two (2) rod holders (along with 2 brackets) and installs on either the driver side or passenger side. The two rod holders mount back to back. This will prohibit the hood from opening with the system installed (you'll need to unbolt it if you need to open the hood). You may also opt to split the two holders and have 1 on the driver side and 1 on the passenger side as well. We've provided sufficient hardware in the kit if you want to separate the two.
FEATURES
Lifetime Warranty for the original owner.
(Photos shown may differ slightly based on final product. The final product may be thicker stainless steel or aluminum).
FEATURES
- .125" #304 Stainless Steel Bracket
- Nylon/Acrylonitrile Butadiene Styrene Fishing Pole Holder
- Powder Coated Black Finish
- Designed & Manufactured in the USA
- 1 or 2 KR Off-Road Brackets
- 1 or 2 Fishing Pole Holders
- Mounting Hardware
- Instructions
- 2021+ Ford Bronco
