Status
Not open for further replies.
Boomba Racing
Boomba Racing
Wood Dale, IL
www.boombaracing.com
BRONCO
Without any further delays we are happy to aanounce our brand new short shifter for the 7 Speed Manual Transmission Ford Bronco! This short shift lever is built for performance without compromising comfort. It installs easily, replacing the OEM shift lever on your Ford Bronco with no modifications required to the surrounding console. The re-engineered lever reduces shift travel by 17%, giving you a shorter and more crisp shifting experience as you row through the gears.
Combine with the Boomba Racing Bronco weighted shift knob for an even better feel!
The shifter and collar itself is designed & manufactured in Boomba's facility, right here in the U.S. and all mounting hardware are included. All shift levers are precision CNC machined black oxide billet steel, anodized billet aluminum and high quality delrin for maximum strength and durability. A definite mod for daily drivers as well as autocross and road racing enthusiast!
Click here to check out the product!
Ford Bronco Boomba Racing Bronco Short Throw Shifter Now Available! Bronco_STS
IF someone previously purchased our shift knob please message us and we will be more than happy to offer a discount code so you guys are not left behind!
BudgetBronco
Tim
Pittsburgh, PA
www.youtube.com
Very curious to see the installation instructions
BudgetBronco
Tim
Pittsburgh, PA
www.youtube.com
OK! I figured there would be a good bit of disassembly required. The instructions look pretty good, and I think I could probably do this without too much worry, possibly except for step 15 "Using the Dremel tool remove material in the marked area to gain access to the spring clip"
Nonetheless I give you guys credit for the time and effort that went in to engineering this and on behalf of the MT community, thank you!
Layman
Voorheesville
2022 Bronco Badlands 7MT
That is where they lost me too, step 15 Remove material with Dremel. LOL.
Looks cool though.
Murph914
Franklin, MA
2008 F-350 reg cab srw v10 manual
Message sent! The knob is nice, but it makes the assembly too high.
MannyG20
Ted
F-150
So, driven manuals my whole life but have never installed a short throw shifter. Can anyone give some real world experience with this type of product? Can you ‘feel’ the difference?
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
Psyched for this and the knob upgrade. Did you ever sort out the concern about the repetitive logos (4) if both were installed?
SPITmadFIRE
CA
… It installs easily, replacing the OEM shift lever on your Ford Bronco with no modifications required to the surrounding console. …
… but it does require dremeling out the shifter housing to access a clip?
SPITmadFIRE
CA
Short throws are common in sports car applications because they provide a faster, more direct and snappy shift experience. Shorter throws feel less sloppy, but you also lose a bit of feeling as to which gear you’re in.
I also drive a Focus RS and honestly that shift feels longer than my stock Badlands 😅 I don’t see any need to short shift this truck, but if someone’s trying to row through gears quickly then more power to ya!
Hkak45
K
Illinois
21 Bronco Black Diamond
This is what I was thinking! On my WRX the stock shifter was super long and flimsy feeling so I got Boomba short shifter and it 100% improved the shift feel and made me love driving the car again. With the bronco I think stock throw is perfect in my opinion. Not too long but not racecar short either. I will definitely get their weighted shift knob though as that makes it feel more solid and temperature neutral
JoeSpeed
Eatontown, Jersey
2dr 2.3 Manual
Im certain things will improve with the short shifter, cant hurt to have 17% reduction
Status
