GoatFab
MI
2021 FE Bronco
Ford Bronco GOAT  PINCH SEAM BLACKOUT PLATES Pinch_001 Ford Bronco GOAT  PINCH SEAM BLACKOUT PLATES Pinch_002 Ford Bronco GOAT  PINCH SEAM BLACKOUT PLATES Pinch_003 Ford Bronco GOAT  PINCH SEAM BLACKOUT PLATES Pinch-004
GOAT Bronco 6th Generation Pinch Seam Blackout Plates are a clean, easy and professional solution for hiding the unsightly pinch seam. Plus, they are compatible with all of our Rock Slider products.
  • 1/8" Steel Plate
  • Includes all Mounting Hardware
  • Comes with 2-Stage Primer & Black Texture Powdercoat
  • Made in the USA
ORDER 2-DOOR
ORDER 4-DOOR
Dzlbudman
Geoff
2019 F250
Would these work with my Outerbanks steps? I think they would but just want to make sure.
Stitchxp626
Chuck
Lancaster Pa
Subaru Forester 2006
Nice. Simple and elegant solution. I am putting Mabett steps on my sasquatch rails, do you think these would fit with those on ?
mattymik
Matt
Houston, TX
2019 Honda Odyssey, 2023 WildTrak
I get why these exist. And my pinch welds bother me (going to paint mine).
But to a non-B6G person, the two pictures would be like a "find the one difference" picture puzzle that no one would figure out.
SubmarineNuke
Richard
Houston, TX
twitch.tv
Bronco Wildtrak
Will these fit with the plate covered rails?
fronc
Frank
San Mateo, California
www.instagram.com
2021 First Edition | 4 Door | Cactus Grey
Also curious if these fit with the factory rock rails. Might need to add to my build before SEMA!
mybikeisred
Paul
Carmel, CA
F250 Powerstroke, Grand Cherokee
Gives an option for a discount code. Hook a brotha up!
TX_Hoss_3.0
Paul
Ram 2500 4X4 Diesel
The clean finished look does make an improvement but my concern is that it’s essentially a gutter to trap debris and hold water. Longevity rust problems?
Black_Stallion13
Cincinnati
Tacoma
Love the look but I have the same concern with these things. Seems like a situation where weatherproof, automotive double-sided tape on the back of it (in addition to bolting it on) would help seal out water/ debris. I guess that could be added easy enough but still not sure I'd risk it lol
