- Feb 15, 2022
- 56
- 212
- 155
- Boston
- Website
- www.offroadalliance.com
- Bronco
- Base
Getting hung up or smacking the lower arm bracket for your rear lower links offroad? Foutz has released their new lower arm frame guard skid for the Bronco Raptor with replaceable HDPE plastic to help prevent being hung up and dragging over rocks as it allows for less resistance and therefore allows the skid to slide more easily than a steel skid. Those of you actually taking your Braptor off pavement know how much of a necessity this item is! The Foutz skid works for all 4dr BRaptors, but not the standard Bronco, and depending on the aftermarket skid you have, tweaking or modifying the skid (one or the other) may need to be done. Also due to the factory location of the gas tank, dropping the tank or replacing the bolt may be required to install this kit, fairly normal as this has been the same procedure for Raptor leaf's for years. This kit is 100% bolt on, with no drilling necessary making it go on fairly easy. Who already has this kit ordered or on their Braptor?? Anyone brave enough to already have trail marks on them?
