- Feb 4, 2020
- 12
- 775
- 885
- Arizona, USA
- Website
- discountti.re
- All Things FORD
- Undecided
Black Rhino releases the Tusk; a 1-piece, monoblock wheel built to handle your toughest off-road adventures!
The Black Rhino Tusk leverages a high density rock guard ring that attaches to the wheel's outer lip, to help prevent damage to both the lip and face of the wheel. The rock guard ring affixes to the wheel using 20 anodized black bolts, that are recessed to help avoid damage and wear that tends to result from off-road use
Once we have internal part numbers and Tusk BR016 is live on our website, we'll update this thread. If you have any questions about this new release, please let us know!
In the interim, check out our catalogue of Black Rhino styles linked below!
Shop Black Rhino Wheels | Discount Tire
-FEATURES-
-BRONCO SIZES & SPECS-
Offset: -10mm
PCD: 6-139.7 (6x5.5)
Bore: 106.10 mm
Weight: 34.76 lbs
Load Capacity: 2,650 lbs
____________________________________
Offset: 0mm
Bore: 106.10 mm
Weight: 34.10 lbs
-GALLERY-
COMING SOON!!!
-FEATURES-
- Contoured and tapered multi-spoke design
- High density removable rock guard ring
- Available in matte gunmetal, matte gold w/machined ring, gloss black, and olive drab green finishes
Offset: -10mm
Bore: 106.10 mm
Weight: 34.76 lbs
Offset: 0mm
Bore: 106.10 mm
Weight: 34.10 lbs
-GALLERY-
