rcl4668
Pacific NW
2019 Mustang Bullitt, 2023 Bronco Heritage Edition
I ordered a set of Heritage Edition Limited rims for my Heritage Edition to use as a set of spare rims for winter tires next season. I recall that someone on the forums was compiling a list of dimensions and specs for the various Bronco wheels so here goes:
OEM Heritage Edition Limited rims, black centered with white lip
Ford Part No. M2DZ-1007-V
17x8.5
Weight 27 lbs
ET30 mm offset
6 x 139.7 (6x5.5) bolt/lug pattern
93.1 hub bore
The weight was measured on my bathroom scale a few times and came out consistently at 27 lbs. I assume these specs are the same for the standard Heritage Edition white rims as the only difference appears to be the paint job between the two.
Ford Bronco Heritage Edition Wheels Weight (lbs) and Specs (offset, width, bolt / lug pattern / hub bore) IMG_3856
Ford Bronco Heritage Edition Wheels Weight (lbs) and Specs (offset, width, bolt / lug pattern / hub bore) IMG_3855
Ford Bronco Heritage Edition Wheels Weight (lbs) and Specs (offset, width, bolt / lug pattern / hub bore) IMG_3854
Ford Bronco Heritage Edition Wheels Weight (lbs) and Specs (offset, width, bolt / lug pattern / hub bore) IMG_3853
Ford Bronco Heritage Edition Wheels Weight (lbs) and Specs (offset, width, bolt / lug pattern / hub bore) IMG_3851
Ford Bronco Heritage Edition Wheels Weight (lbs) and Specs (offset, width, bolt / lug pattern / hub bore) IMG_3852
Ford Bronco Heritage Edition Wheels Weight (lbs) and Specs (offset, width, bolt / lug pattern / hub bore) IMG_3850
Ford Bronco Heritage Edition Wheels Weight (lbs) and Specs (offset, width, bolt / lug pattern / hub bore) IMG_3849
Bschurr
NY
RagnarKon
Bryan
New England
Ford Bronco, Escape, Focus
I did not know the hub bore dimensions for the wheel. Is that something that is listed in one of the pics below or does anyone know what the hub bore is for these rims? Thanks!
93.1
And thanks for the tag @Bschurr ... updating the list.
604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
93.1 is the hub bore? Thank you so much!
Might want to update/edit your original post with that - Lots of people won't read further than the first post :ROFLMAO:
DarkHelmet
James
MI
N/A
Where did you order these? And how much did they run you?
tock13
Tony
WA State
x2 on the above post. I would love to get a set, powder coat them gray to replace my SAS wheels with.
rcl4668
rcl4668
Pacific NW
Where did you order them from?
My Ford dealer where I purchased my HE. The wheels came in fairly quickly, about two weeks turnaround. Much pricier than aftermarket options like the Fifteen52 Analog HD wheel.
rcl4668
rcl4668
Pacific NW
$633.44 per rim. Again, pricier than most aftermarket options but I liked the OEM look and the 30mm offset compared with the 0mm offset of the Analog HDs (which is also a great looking rim).
rcl4668
rcl4668
Pacific NW
It looks like the magical internet fairies already edited my post for me!
peterh
ny
jeep wrangler jlu 2018
I really wish an aftermarket company would do a wheel like this in polished aluminum and high offset - there is a gap in the market for that retro mag wheel in polished and at minimum poke offset. Lots of old school broncos don't poke!
rcl4668
rcl4668
Pacific NW
Agreed. I was ready to pull the trigger on the Fifteen52 Analog HD in white (beautiful wheel!) but that zero offset made them stick out just a bit too much for me.
Rumbloki
Alton
ATX/PCB
ZR2, 1973 Mach 1
Do you have a link?
I don't know why this thread is a sticky and your list doesn't seem to be. Maybe I overlooked it?
