ORACLE Terry
Terry
New Orleans, LA
Bronco, RAM TRX, Gladiator, Wrangler JL,
The cargo area is virtually overlooked in lighting from Ford. The Ford Bronco is a great vehicle, but one area for improvement is the factory LED interior lighting in the cargo area. The existing lighting doesn't provide enough usable illumination for the rear cargo area. ORACLE Lighting has developed an integrated cargo light module to easily add a bright LED light to the rear hatch cargo space and the area around the vehicle! This Ford Bronco cargo light uses the vehicle's existing 12V power source and simply replaces the factory wiper motor cover. Installation is simple.
Ford Bronco 🔦 Product Spotlight 🔦 LED CARGO LIGHT FOR 2021-2024 FORD BRONCO Oracle_Lighting_Bronco_LED_Cargo_Light
Order yours today using the exclusive Forum discount code: BRONCO10
https://www.oraclelights.com/products/ford-bronco-led-cargo-light-module
Ford Bronco 🔦 Product Spotlight 🔦 LED CARGO LIGHT FOR 2021-2024 FORD BRONCO Oracle_Lighting_Bronco_LED_Cargo_Light_1
Ford Bronco 🔦 Product Spotlight 🔦 LED CARGO LIGHT FOR 2021-2024 FORD BRONCO Oracle_Lighting_Bronco_LED_Cargo_Light_2
Rosalieee
R
LA, CA
Raptor, BMW M3 Competition X-Drive
Is yours a physical switch? Or a contact switch? Seems that all the products with the contacts which have an issue random activation after a while
ORACLE Terry
ORACLE Terry
Terry
New Orleans, LA
Its a physical switch to push in.
RynoRanger
Chuck
Gilbert, AZ
azbluey.com
2.7L Badlands NS 4dr
What's the best hard-wire install option? I assume the wiper motor doesn't have steady power, just a long switchleg running back to it. Maybe still have to run that wire to the 12v socket but pop off that back side-panel and splice in behind the cig lighter?
I live in phoenix... that tape holding the wire... will not last a single summer. Have to look at other options there too.
That all said - the product is great; probably pick one up and figure out the wiring.
Shawn_1121
Shawn
Hudson, NH
22 Bronco OBX A51
had one of these in my JL and loved it.
HeHateMe
San Antonio, TX
2020 Hyundai Palisade
I used this for the contact switch one I installed that @Rosalieee mentions...
Makes for a much cleaner install.
Cord hider
Ford Bronco 🔦 Product Spotlight 🔦 LED CARGO LIGHT FOR 2021-2024 FORD BRONCO 1000060189
RynoRanger
Chuck
Gilbert, AZ
azbluey.com
Noted. The tape stuff doesn't last long here in phoenix... more of it though with this 'channel' solution. thx
GlueBoy
gluefactoryoffroad.com
21 Bronco
I live in Phoenix and have this unit installed. The adhesive works fine. I park my rig outside. I'm happy to show it off to you in person if you want to check it out. Just DM me.
Ogre
James
'23 BD 2dr 7MT CG, '18 Indian Chieftain
How much bigger is this than the wiper cover it replaces? 2dr already has little enough room. I don't want it to hit the cooler I keep back there
ORACLE Terry
ORACLE Terry
Terry
New Orleans, LA
We're running it on our 2 door and I don't really notice it. It isn't a much bigger footprint than the wiper housing cover.
Mjasi3
Chicago
following
jwysopal
James
Los Angeles
2021 Ford Bronco Black Diamond
Looks like a great option. I would do this if I didn't already have a full custom hardwired lighting solution under my steel enclosure lid.
Now my passenger Oracle flush taillight is freaking out and only portion of it is not coming on. Doesn't seem like a wiring issue so far, and wondering if the LED chips are already bad at only just over a year old. Not sure if the "1 year" warranty is extended when I registered them at purchase? Maybe Oracle can chime it to help. 😐 @ORACLE Terry @ORACLE Lighting
But again, love that this is a button switch for cargo light. Maybe I'll still get one for the main cargo area above the steel enclosure. ✌
ORACLE Terry
ORACLE Terry
Terry
New Orleans, LA
Make sure to take a moment to fill out our online tech support request here: https://www.oraclelights.com/pages/tech-support-form and someone from our technical department will be in contact with you shortly.
