GroovyGeek
Boyan
'23 Bronco BD
A Benjamin and a half? Thanks but no thanks. I can buy ###two### LED strips for three Hamiltons and get a better distributed light both inside and outside the cab that is much lower profile.
https://a.co/d/7VD2l5L
Newbrunny
Craig
New Brunswick
2022 Bronco
It is a good product and does what it is intended to. However if you like things to fit perfectly flush, it does not.
And yes I have had multiple emails with Oracle and they even sent me a “Gen2” version which fit flush marginally better. I did not bother following up after replacing “Gen1” with “Gen2”. It is what it is…
But to be clear it is a good light and fills a need.
ricstang
Richard
Lincoln, NE
1995 Ford Bronco
What about soft tops?
TheLawnDart
Austin
Las Cruces
FJ Cruiser, Subaru Forrester, Hyundai Palisade
What's the best hard-wire install option? I assume the wiper motor doesn't have steady power, just a long switchleg running back to it. Maybe still have to run that wire to the 12v socket but pop off that back side-panel and splice in behind the cig lighter?
I live in phoenix... that tape holding the wire... will not last a single summer. Have to look at other options there too.
That all said - the product is great; probably pick one up and figure out the wiring.
I got this unit a while ago (so probably the first generation?) and it has been super awesome. I ran the wire along the hard top glass and down the strut. I spliced mine into the rear cargo light rather than the 12V socket then used a simple quick release for when I take the top off (like it is now) that I just tuck between the trim. This way I can turn the light on anytime the car is on or whenever I open the trunk. It stays on for a while after the doors are all closed too
Ford Bronco 🔦 Product Spotlight 🔦 LED CARGO LIGHT FOR 2021-2024 FORD BRONCO IMG_9024
Knownman
Matt
Santa Clarita California
2021 Bronco Badlands Sasquatch.
The cargo area is virtually overlooked in lighting from Ford. The Ford Bronco is a great vehicle, but one area for improvement is the factory LED interior lighting in the cargo area. The existing lighting doesn't provide enough usable illumination for the rear cargo area. ORACLE Lighting has developed an integrated cargo light module to easily add a bright LED light to the rear hatch cargo space and the area around the vehicle! This Ford Bronco cargo light uses the vehicle's existing 12V power source and simply replaces the factory wiper motor cover. Installation is simple.
Order yours today using the exclusive Forum discount code: BRONCO10
https://www.oraclelights.com/products/ford-bronco-led-cargo-light-module
Looks like a solid option but,
I don't really see any photos demonstrating how well it illuminates the interior cargo area at night. That's where it would primarily be noticed. I'm assuming it's better but not seeing a before and after leaves a lot to the imagination. Could you post some up for us? The link doesn't have much more either. Maybe an install on a vehicle that has a drop down tailgate table would help to understand how well this product actually works.
And one thought regarding the illumination on the trail. A red or amber mode is highly encouraged to reduce the mosquitos flocking to the kitchen.
Thanks,
Matt
ORACLE Terry
ORACLE Terry
Terry
New Orleans, LA
Bronco, RAM TRX, Gladiator, Wrangler JL,
Thanks,
Matt
That's a good point. I have our show Bronco and I'll see if I can get some night shots in the next few days.
Los
Disco3
That looks nice, but IMO too much moola for a light unit with a switch...
Mean Green
Bill
Warminster, PA
23 Ford Bronco 2dr Badlands Sasquatch
Rear accessory light turns off in 10 minute, outlet turns off in an hour.
Direct wired to the light with the switch on would allow for the light to be used as a much brighter accessory light or switched lighting.
Wired to the outlet gets you tailgate table lighting to cook, etc…
Water proof two wire plug at the rear top of the panel would allow for a quick disconnect to remove the top.
Nilight - 50020R 2Pin Way 16AWG Waterproof Wire 1.5mm Series Terminal Connector-10 Pack,2 Years Warranty https://a.co/d/1T7iWoP
Wire channel for the rear window was noted earlier.
D-Line TV Cord Hider, Patented Half Round Cable Cover, Hide Wall Mount TV Wires, Hinged One-Piece Cable Concealer, Paintable, Adhesive, Decorative Raceway - 0.78in W x 0.39in H x 15.7in L - Black https://a.co/d/3QJAhJc
ORACLE Terry
ORACLE Terry
Terry
New Orleans, LA
Thanks,
Matt
LED Rear Cargo Light on!
Ford Bronco 🔦 Product Spotlight 🔦 LED CARGO LIGHT FOR 2021-2024 FORD BRONCO IMG_3100
Ford Bronco 🔦 Product Spotlight 🔦 LED CARGO LIGHT FOR 2021-2024 FORD BRONCO IMG_3102
With the Cargo Light off:
Ford Bronco 🔦 Product Spotlight 🔦 LED CARGO LIGHT FOR 2021-2024 FORD BRONCO IMG_3096
ORACLE Terry
ORACLE Terry
Terry
New Orleans, LA
Oh yes that is quite a bit better than what I have now. Thank you
The bottom photo is without the light. It's amazing what this light does.
ORACLE Terry
ORACLE Terry
Terry
New Orleans, LA
Ford Bronco 🔦 Product Spotlight 🔦 LED CARGO LIGHT FOR 2021-2024 FORD BRONCO D2DD7EDE-3FC7-4996-800B-64EEBCBAA544_1_105_c
ORACLE Lighting
ORACLE
New Orleans, LA
oraclelights.com
Thanks,
Matt
Check out some of the footage at the end of the video to see how it illuminates outside of the truck.
ORACLE Terry
ORACLE Terry
Terry
New Orleans, LA
