NOW AVALIABLE: ORACLE LIGHTING 2021-2023 FORD BRONCO LED OFF-ROAD SIDE MIRROR DITCH LIGHTS
KFreakin
Kenny
Tennessee
23 Badlands
Hey there!
There are small guide fins along the mirror cap that need to be precisely in line for the cap to clip in fully. Also, there's a rubber gasket at the base of the mirror arm that you need to keep an eye on as it can push on the end of the cap, making it bow out.
Messed around with this over 2 hours and had a local shop even look at it. Still not fitting. The problem seems to be the camera not fitting flush. And being partially blocked
ORACLE Lighting
ORACLE
New Orleans, LA
oraclelights.com
If your camera is not fitting there may be some slag there for the de-molding of the part. You can use a countersink bit to clean away any slag that may inhibit the camera from seating fully. This should correct the issue you are referring to.
KFreakin
Kenny
Tennessee
23 Badlands
Wouldn’t doing this cause a bigger hole and allow more moisture to enter the housing?
Regardless I don’t see any slag. Everything appears lined up but the camera hole. Might need to just replace the driver side housing.
JP_Oracle
JP
Metairie, LA
21 Bronco
Can you PM me a photo of the opening please so we can have a look?
  • Like
Reactions: FFF
Gotchaa
Los Angeles
Tesla
why are so many people have fitment problems, is this a molding problem? Your video says 20 minute install and we’ve got ppl here spending 2 plus hours? There are 9 steps in your instructions that make this seem easy,
Now a bunch of caveats with gaskets and foam backings, asking customers to file parts to fit?
Can you please update us if there is a manufacturer molding issue? I have mine already and I am not about to take things apart until you confirm install process and cap molding is correct Or there needs
To be an updated revision. I also have cameras, puddle lights, etc….maybe you guys only tested your molding on setups that didn’t have these options? Back to the drawing board?
I am not looking for good enough fit comprise, it either fits properly or it doesn’t.
please update this thread or this is going back before an attempt to install.
  • Like
Reactions: FFF
JP_Oracle
JP
Metairie, LA
21 Bronco
What we've seen is a small burr left over from demolding of the part on the LH unit. This can be removed easily with a step bit.
Ford Bronco NOW AVALIABLE: ORACLE LIGHTING 2021-2023 FORD BRONCO LED OFF-ROAD SIDE MIRROR DITCH LIGHTS 1685982387520
Ford Bronco NOW AVALIABLE: ORACLE LIGHTING 2021-2023 FORD BRONCO LED OFF-ROAD SIDE MIRROR DITCH LIGHTS 1685982397863
Gotchaa
Los Angeles
Tesla
I would not recommend purchasing this until the molds are corrected. On both mine the fitment is very poor at the top with larger that OEM gaps. The drivers side is not molded properly. It’s not a 20 minute install, and anyone installing it can get it on but its not going to fit properly without modification. This is very disappointing the QA on these is so poor. I will also share my experience with Oracle support over the phone or email is slow. Not what you would expect.
You spend hundreds of dollars on an item, and you expect it to fit. It does not.
Chritaka
DFW, Texas
'23 WildTrak; '06 Whippl'd Mustang (sold4upgrades)
Were these fitment/install issues ever addressed? I was considering getting these, but don't want to deal with these types of issues.
  • Like
Reactions: FFF
ORACLE Lighting
ORACLE
New Orleans, LA
oraclelights.com
Yes, we made some adjustments to the shot on the latest production run to be sure there was not any slag on the camera opening which could cause difficulty with the camera.
FFF
Calling all Canadians and other Law Abiding Citizens!
Our Magnetic Cover for ORACLE Lighting LED Off-Road Mirrors is here!
This magnetic cover for ORACLE Lighting LED Off-Road Mirrors adds greater protection and legal compliance for on-road driving. This innovative cover utilizes a heavy-duty magnetic plate which is easy to put on and take off. The strong magnetic force prevents the cover coming off unintentionally and ensures compliance when the lights are not in use. When the Lights are in use, the cover is easy to store due to its slim profile.
Product Features:
- Pack includes 2x covers
- Black magnetic cover for ORACLE Lighting LED Off-Road Mirrors
- Subtle ORACLE Lighting branding
- Easy installation and removal
CLICK HERE FOR MORE INFORMATION AND TO ORDER YOURS
When you mention "to ensure compliance", does this mean they may not be legal for use on the road? Like only for off-road use? Do they come in yellow also or just white light? They look great!
OracleLights
OracleLights
New Orleans, LA
www.oraclelights.com
These are Off-Road Side Mirror ditch lights. They aren't design for on-road use. Some states require that off-road lights/light bars are covered when not in use.
Currently these are only available in a white 6000k color temperature. Keep the questions coming!!
