💥NOW IN STOCK💥 ORACLE LIGHTING 2021-2024 FORD BRONCO OFF ROAD LASER AUXILIARY LIGHTS
ORACLE Terry
Terry
New Orleans, LA
Bronco, RAM TRX, Gladiator, Wrangler JL,
Ford Bronco 💥NOW IN STOCK💥 ORACLE LIGHTING 2021-2024 FORD BRONCO OFF ROAD LASER AUXILIARY LIGHTS ORACLE_Lighting_laserfog-na
Featuring both an individual SAE Fog Light and two individual Off-Road Laser Auxiliary Light Modules, this new modular kit from ORACLE provides unparalleled lighting features for your new Bronco. The Fog Light features a single LED which functions to provide the user with additional lighting on road in a DOT/SAE- compliant fog light beam pattern to increase night time visibility.
Order yours today! https://www.oraclelights.com/produc...road-laser-led-fog-light-kit-for-steel-bumper
The fog light module has separate cables which can be connected to the factory fog light switch (if equipped) or to an auxiliary switch. If the Bronco is not equipped with the optional Aux Switches ORACLE offers a harness (Part# 2088-504) for easy wiring installation. The Laser auxiliary lights are intended for off-road use only and should be connected to an Aux switch.
Ford Bronco 💥NOW IN STOCK💥 ORACLE LIGHTING 2021-2024 FORD BRONCO OFF ROAD LASER AUXILIARY LIGHTS ORACLE_LIGHTING_BRONCO_OFFROAD_LASER_LIGHTS_KIT_STEEL_BUMPER
The skeletonized mount holds the individual futuristic LED and Laser Emitters with full leveling capabilities built into each individual emitter for functional aiming for the light. The Fog Light and the two individual Laser Auxiliary Light Modules each come in their own separate die-cast aluminum housings (three in total) which are individually adjustable when connected to the skeletonized mount.
Ford Bronco 💥NOW IN STOCK💥 ORACLE LIGHTING 2021-2024 FORD BRONCO OFF ROAD LASER AUXILIARY LIGHTS ORACLE_Lighting_Laser_Fog_Mount
ORACLE Terry
ORACLE Terry
Terry
New Orleans, LA
Ford Bronco 💥NOW IN STOCK💥 ORACLE LIGHTING 2021-2024 FORD BRONCO OFF ROAD LASER AUXILIARY LIGHTS 53196868743_ca3ffd62ba_c
