A little wheel help...
H3llR4z0r
Ryan
TX
2024 Ford Bronco
So it's getting time to put tires on the station wagon. I wanted to upsize to an 18" wheel as well, but keep somewhat close to a factory look... maybe...
I had AI create this image - and this was the wheel I originally wanted (still like it, but maybe other options to weigh).
My issue is, when I go up to an 18", what offset would be similar to factory on the Wildtrak, or at least not inset anymore. I wouldn't mind a little more width but not necessary.
If anyone has an suggestions as far as tire size or a wheel to check out, I'm all ears. These wheels are definitely not cheap ($370ea on their website).
Ford Bronco A little wheel help... Gemini_Generated_Image_
Smocaine
DFW, TX
Cervelo Caledonia
Almost any wheel you can find will have less inset due to the fairly deep +30 offset of the factory Sasquatch wheels. 0-offset wheels (most common) would give you about half an inch more poke on either side, assuming the same wheel width.
H3llR4z0r
H3llR4z0r
Ryan
TX
2024 Ford Bronco
Most wheels I find are 18x9, so you'd say that would make it about 3/4 of an inch further outon each side right?
The guy at Wheelpros I talked to may have known exactly what he was talking about - he just didn't seem too sure. He said go with 1mm offset (I usually find 18x9 in 12mm offset or 1mm).
EasternSierra
Sacramento metro, California, U.S.A.
2025 Bronco Badlands 4-door 7MT, 2023 Ford Transit Connect van
Wider wheels don't mean more poke. That's affected by wheel offset and tire width. Of course, if you go to wider tires for the purpose of fitting wider wheels, then you have more poke.
Smocaine
DFW, TX
Cervelo Caledonia
The face of the wheel will be further out with a wider wheel but that doesn't translate directly to tire poke.
Also I did my math wrong, 0s would be a little over a full inch on either side relative to +30s, and +12s about 3/4".
H3llR4z0r
H3llR4z0r
Ryan
TX
2024 Ford Bronco
You know you greatly reduce tire option with an 18? The ones that are there are often E rated.
I actually haven't looked into that.
I just like the thought of a larger wheel, without going to a 20 - which I think might be too big.
Now I'm on the fence lol.
Valhalla
Valhalla
Chattanooga Tn
Check out your choices, you may be happy, look at price also.
rayhil67
Ray
Douglassville pa
22 2dr Bronco, 06 hummer H3, 01 SuperDuty F250
Might want to give these guys a look EXT If you get the tire and wheel package they give pretty good discounts + military if applies, I used them on most of my jeeps. I too have hit the 65K mark and looking at wheels/tires soon going to stay at 17 inch but was looking at getting a little poke. I like my steelies and not sure I want to drop 1200+ on wheels, so might go the spacer route decisions, decisions...
Fast Eddie
Ed
NY
2025 4Dr OBX, 2025 Navigator BL
On my OBX I actually went down to a 17" because of the more limited options of tires, many of which are E rated and the higher cost. Dropping to a 17 was a win win win...
AZ_Liberty
2007 Expedition
18" is sort of a outlier in terms of availability for decent tires. You have a lot more better choices at 17, as well as better performance of course.
If you really want 18s. OBX rims are basically free on Facebook Marketplace or Craigslist.
ThunderFlash
Doug
Washington
'24 4-dr WT, '22 2-dr WT, '15 Explorer Sport, '02 F250 SD V-10
AI says that image is a scale representation of an 18" wheel with....a 35" tire? Man, that wheel looks more than +1" on the diameter to me. I'm generally not a fan of all black wheels, they get lost in the darkness of the tires and wheel wells. But, they work OK with the Ox White/Black theme. Under casual circumstances, though, I probably wouldn't immediately notice that wheel was different from the OEM beadlock capable black wheels we have on our Ox WT. My eye just goes elsewhere. Put a polished, gun metal, or bronze wheel on there and it screams, "check these out".
