- First Name
- Adam
- Joined
- Aug 30, 2021
- Threads
- 355
- Messages
- 4,384
- Reaction score
- 5,849
- Location
- Lindenhurst, NY
- Website
- www.4x4TruckLEDs.com
- Vehicle(s)
- 2018 Raptor & 2021 Bronco Outer Banks
- Your Bronco Model
- Outer Banks
- Thread starter
- #31
You need to tap into the 2 wires explained...All I've ever asked you for is a pin out of the for the Ford module, if you even have one. This pic is only helpful to find to the connector. Attachment points are obliterated.
I've identified 3 wires, moreso out of a process of elimination, and only one is purple, the other two are gray. I want to make sure the wires I believe to be correct are. I have tapped the purple wire and each of the gray wires in different instances and nothing works, either side. What you sense as hostility is extreme frustration. The six wires I was referring to are these two, the two purple wires that also attach to the OBD connector, the power and the ground. I've found a few diagnostic processes on AMP website I'm going to try today. I'll wait to hear from AMP.
Grey with Orange Stripe
Purple with Orange Stripe
There are not two grey wires to tap into. So if you are tapping into two grey wires you are tapping into the wrong wires. You need to tap into the correct wires, which are in the bundle I outlined in red.
Please share a photo of what you tapped into.
