AR | MAGNUM STIRRUP® Full Length Billet Aluminum Side Step for OEM Rock Rail - Bronco6G Exclusive Part
JakeNYC
NYC
2023 Black Diamond Sasquatch
Badmommallama
Candice
Auburn, AL
2020 Mercedes GLB
Send it! Please.
kojack19
CT
Ford F150 Raptor
Send it please! Thank you.
Ogre
James
'23 BD 2dr 7MT CG, '18 Indian Chieftain
@EIGHTLUG and crew SENT IT!
These things are nice and, as always, the AR merch game is top notch! Looking forward to installing them this weekend.
Ford Bronco AR | MAGNUM STIRRUP® Full Length Billet Aluminum Side Step for OEM Rock Rail - Bronco6G Exclusive Part 77106FC9-A9BD-4FD0-812B-33C0D4DB7C4C
Just curious when you ordered? Mine should be here before the end of this month. I'm so thankful I ordered before I even got the truck because the family is really looking forward to having the help getting in.
Johnny Rebel
LA
2021 2D Big Bend, 2022 Bronco Raptor
I think it was late November or early December. You’ll love them!
Seattle
Land Cruisers
Send it.
You already knew we weren't going to stop with just the STIRRUP. Ladies and Gentlemen, I bring you the MAGNUM.
AR | MAGNUM STIRRUP is live on the website for pre-order. We crunched the numbers and bought up 240' worth of 6061 billets to get the product more cost comparative to the 4 door STIRRUP. There's just no way getting around the volume of material necessary to make this size magic happen.
2 Door: $1,245.00
4 Door: $1,395
With the Bronco6G 20% forum discount, it's shipped to your door for:
$996 for the 2 door
$1,116 for the 4 door
Some of you hit pause on your STIRRUP order to allow the release of the MAGNUM pricing. Go ahead and fire off another email ([email protected]), if you're a go or no-go. If you're a go, we'll create a special code at checkout for just the difference of the MAGNUM. For everyone else that has already said SEND IT on the thread, we'll PM you the 20% off code. The 20% off code will be available to all Bronco6G members forever ever.
We're using 12' x 6" x 1.75" of USA made 6061 billets that we are cutting down to size, and machining right here at STARKILLER BASE, to make each and every MAGNUM STIRRUP. If you have an overland build, trail conquering rig, or your daily driver the MAGNUM will fit the bill. It's five inches of width will give your boot or shoe a proper platform to assist you in climbing up in the saddle, conveniently reaching gear on your roof rack, it will protect your BRONCO from shopping carts and car doors, or just something awesome to admire.
Those of you that have any of our products know that nothing we do is rinse and repeat jeep level engineering. This is all multi-op, chamfered edges, post machining, color matching OEM+ GOODNESS. Our entire intent is for our MAGNUM to look like it was on your BRONCO from the factory.
Let's call it 60" for the two door MAGNUM and add fifteen more inches of length for your four door MAGNUM. I've been around billet car parts for a while and the MAGNUM has to be one of the largest billet aluminum parts to be used and semi mass produced in the automotive world. It kind of has to be, to be called the MAGNUM, right?
The entire MAGNUM, along with its Clamps, are coated in a powdercoat that we went to great lengths to, to ensure it closely matched the color that FORD uses, furthering the OEM+ appearance, and not a aftermarket bolt on. Then, if you so choose, we post machine to remove the powdercoating from the top surface and reveal the raw billet aluminum and provide a very classy contrast. This will also give the MAGNUM years and years of striking good looks and no rust... ever. The more you step on the MAGNUM, the more naturally worn the aluminum will look but it won't affect the powdercoating.
MAGNUM is mounted to your OEM rocker rail with 4 Clamps each and M8 and M10 316 stainless fasteners. Nothing but the best. A single M8 bolt alone has 110,000 PSI tensile strength! The MAGNUM is definitely more solid than the rail it's mounted to. With its coating and the use of aluminum and stainless, the MAGNUM will require little maintenance and it will last the life of your Bronco.
The MAGNUM will be sold in a pair. You'll select 2 Door MAGNUM or 4 Door MAGNUM from the drop down. This will also be a BRONCO6G exclusive part, at launch, and B6G members will always be eligible for the 20% discount.
AR | MAGNUM Clamp Bracket
The Clamp on bracket is standard for both 2 Door and 4 Door MAGNUM. Both the 2" drop location and standard height (more even with the top of the OEM slider, are available on the Clamp Bracket.) This is the same tried and tested Clamp used with the AR | STIRRUP. We just doubled up the clamp number for both looks and just in case you want to take a family photo of everyone standing on a MAGNUM. *The first family that posts a pic doing this will each get our new Overland Bronco shirts. ;)
The Clamp is secured with a pair of M6 316 stainless steel bolts. We apply a heavy duty rubber isolator to our Clamps to ensure there is zero metal on metal contact with your OEM rail. No metal chaffing means no wear on your rock rail's finish. And for those in the salt belt, that means less rust and corrosion on that steel part.
The Clamp bracket is easily installed and removed. We're talking minutes. Not so crazy easy that you would need to worry about theft. All of the mounting hardware is hidden from view and also placed in a counter bore in the Clamp to ensure the bolt head is never worn away or damaged by road debris.
*I'll continue to update this thread with detailed pics and the machining process. This is going to be fun!
Pricing:
Retail price for the AR | MAGNUM will be released soon! Like real soon!
BRONCO6G members are eligible for a 20% discount.
UPDATE: 8/3/22
Production is rolling on Pre-Orders!
MAGNUM Production Schedule
Order #Machine DatePowder CoatPost MachineEstimated Shipping Window
wk 110330-109756/30- 7/87/8-7/15TBD7/16-7/19
2778-28036/30-7/87/8-7/15
wk 22860-32197/9-7/157/15-7/22TBD7/23-7/26
7/25-8/2
wk 33226-32937/16-7/227/23-7/29TBD8/2-8/6
10683-10827
wk 43303-33288/1-8/78/5-8/11TBD8/11-8/19
10842, 10975, 2797, 2801
wk 53336-34668/8-14th8/12-8/18TBD8/18-8/26
3194-3210
wk 63542-36988/15-8/218/19-8/25TBD8/25-9/2
39833234-3393
wk 73734-38418/22-8/288/26-9/19/1-9/9
3479-3397
wk 83869-39428/29-9/49/2-9/89/8-9/16
3568-3827
wk 93943-39889/5-9/119/9-9/159/15-9/23
3843-3876
wk 104006-40889/12-9/189/16-9/229/22-9/30
wk 114107-41539/19-9/259/23-9/299/29-10/7
[email protected]
We are super excited for these to start shipping!!
2 Door: $1,245.00
4 Door: $1,395
$996 for the 2 door
Pricing:
UPDATE: 8/3/22
7/25-8/2
10683-10827
3194-3210
39833234-3393
3479-3397
3568-3827
3843-3876
[email protected]
[ATTACH
Send It.
Johnny Rebel
LA
Great call to go post machined with those wheels! 🔥
@EIGHTLUG , I appreciate that and couldn’t agree more! Post machining is worth the wait.
Speaking of the wheels, there’s another small detail (actually 27 of them) that should make you and the AR crew smile…
JaxDiego
Granbury TX
22 Badlands
Ok I need the lugs now. Awesome taste my dude!
Ford Bronco AR | MAGNUM STIRRUP® Full Length Billet Aluminum Side Step for OEM Rock Rail - Bronco6G Exclusive Part 20221021_142440
EIGHTLUG
EIGHTLUG
Curtis
Silverdale, WA
G2 Raptor, GT350, Land Rover SERIES and DEFENDER
I’m a big fan of quality lug nuts. It’s like a proper pocket square to go with your tailored suit.
