AR | SLAP / BPM - This is the bulletproof mount
Shawn_1121
Shawn
Hudson, NH
22 Bronco OBX A51
The BALLS SLAP combination
how can i mount a go pro using the center slot? anyone have any ideas on what size that whole is?
going on a cruise and would love to be able to capture it on vid. any help is appreciated. thank you in advance
AceGoliath
Charles
IL
21 Bronco OBX SAS , 22 Maverick XLT, 10 Fusion SE
Threads are 1/4-20 for the attachment points.
Can rig up something simple utilizing stuff like this:
https://www.amazon.com/Fotasy-Threaded-Screw-Adapters-Pieces/dp/B00KQXJ66A/ref=sr_1_1?crid=4ORSQIPXSPKU&keywords=1/4-20+threaded+go+pro&qid=1665147270&sprefix=1/4-20+threaded+go+pro,aps,88&sr=8-1
https://www.amazon.com/Tripod-Adapter-Camera-Mounting-Accessory/dp/B07ZSGBVKH/ref=sr_1_3?crid=4ORSQIPXSPKU&keywords=1/4-20+threaded+go+pro&qid=1665147375&sprefix=1/4-20+threaded+go+pro,aps,88&sr=8-3
rhinojlu
Oreste
Long Island
Picked up the Bronco at 4pm… mount was installed by 5pm
Ford Bronco AR | SLAP / BPM - This is the bulletproof mount FD30C78B-0AAB-4CF3-8CAA-18F31B256441
Hey man do you have links to those arms and that arm extension by any chance? I'm guessing you're using the 20mm balls
Shawn_1121
Shawn
Hudson, NH
22 Bronco OBX A51
67 designs
Toomuchgear
Northern California
Jeep, Lexus
This helped a lot, thanks! (y)
I was trying a credit card but didn't really do the trick. I didn't have any plastic pry bars either. I installed an BALLS in the center hole and just used that to pulled straight up and the OEM piece came right out.
I received and mounted mine.
After removing the two OEM screws, the instructions tell you to use a plastic pry tool to disengage the clips on the OEM mounting apparatus. The clips are at the two corners of the OEM apparatus closest to you. I did not have a plastic pry tool, so I inserted my AR BYODR screw into the center hole on the OEM apparatus and then placed a flat-edge screwdriver under that screw and gently pulled the entire thing upwards to expose the clips. Then I just wormed my finger under the plastic and pulled up the rest of the way to completely remove the OEM apparatus.
Hope this helps for those receiving their mounts!
Deltamav
Ben
Cherry Hill, NJ
2022 Badlands
Nice, same basic concept that I was describing!
Dickzip
Everglades
Todd
S/w florida
Everglades
@EIGHTLUG dam it I just ordered this and now I found the code for members, can u send me balls or something?
5445 order number
and where are the Everglades Badges? Lol
EIGHTLUG
EIGHTLUG
Curtis
Silverdale, WA
G2 Raptor, GT350, Land Rover SERIES and DEFENDER
5445 order number
We can add an extra patch in your order and we’re getting closer on the EVERGLADES fender badge.
Ford Bronco AR | SLAP / BPM - This is the bulletproof mount 6AF27DD1-39E3-4141-B63F-F9A4EA2C107E
JonDW29
Jon
NoVA
'16 F-150
Finally grabbed one of these. I don't have the need for the full accessory rail, but feel like this gives me some options for mounting past the flimsy factory option.
DallasCajun
Will
Dallas, TX
2023 Ford Bronco Raptor
Ordered…no more worrying about the flimsy ‘Accessory Ready’ piece.
JonDW29
Jon
NoVA
'16 F-150
The tackform phone holder I was using doesn't have a long enough mounting screw to mount on the BPM. Anyone know the right thread type, etc. offhand? Need to track down some longer bolts.
