Aux wiring question
karijohn007
Kari
Wisconsin
2022 Bronco outer banks
Hi everyone. I'm new to all of this and have spent days reading threads and going down rabbit holes about topics I didn't know I had interest in.
My main question is this...
I have the oracle badge lights and fog lights. Can I wire them both in the purple pig tail up front and then connect two different switches on the back end? Or can only one thing go into that purple one up front?
I'm new and learning so please talk in simple terms!
Thanks, hopefully that makes sense!
BroncoSarge
Jeffrey
Fort Bragg, North Carolina
2021 AMB Bronco, 2021 CO Bronco
If you’re asking if you can hook up two items to a switch? They are rated for different amps. As long as you don’t exceed the amperage, should be fine.
If you want them switched differently, the you will have to wire them separately to the switches.
cmcbronco
Illinois
2012 f-150 FX4
the purple wire comes out by the 6 pigtails that go to aux switches. You’ll only be able to hook it to one switch there so both accessories you wire up front by the grille will be on one switch.
karijohn007
karijohn007
Kari
Wisconsin
Got it, thanks guys. So basically....use two different wires!
Appreciate the help!
