Badlands Build and Price 'quirk' I experienced
JMBGlass
Josh
Brattleboro, Vermont
2018 Toyota Tacoma/C.O. Badlands 2.7 4Dr hardtop
Hi there,
I was going over the build and price tool on Ford's site just now, and I was trying to spec out a Badlands I have a
reservation in for. But I found it odd that when I tried to add their "paint protection film" option, adding "roof rails with
crossbars", or adding the "sound-deadening headliner" option all made the build and price tool make me change back
to the smaller 2.3 engine. But what's extra odd is that, for shits and giggles, I entered the same specs in for an Outer Banks
model and there was no problem whatsoever with the engine type having to change back to the smaller size with those other
options mentioned above selected.
Anyone else experience this? I'm hoping it's just a website quirk..
amccue90
Andrew
Illinois
2021 Badlands
Got to use the search function for the forums man. Been discussed in various threads and a Q&A with the Ford Brand Manager.
GVWR issue. Badlands is too heavy for their dumb system to allow all options.
Philly
Dallas, TX
2022 JL Rubicon
This is common. Ford has limited certain item combinations based upon max GVWR. The four-door Badlands seems to suffer the most from this, likely because it has heavy duty bumpers and skid plates standard. Whether all items will be restricted at order time is unknown, but the roof rack and Sasquatch Package combo is one known to be unavailable until model year 2022.
You may still be able to add some of these things on at the dealer if you cannot order the Bronco with them from the factory.
Squatch
Miami
I'm afraid the Rockstars let us down
Jpeyer
Joshua
Ohio
2017 F250 Lariat
If you have ever bought a new truck, you would understand gvwr and payload issue. Badlands 4 door is just very heavy and has options limited. ‘22 will be lighter supposedly but lose features to achieve this. At 6180 pounds gvwr and 1100 pounds payload that is the reason there is no roof rack allowed. 5 people at 150 is 750 plus 320 hitch weight is at your max gvwr. Ford either gives you passengers and cargo or passengers and towing. They chose towing on the badlands. Buy it at the parts counter. The ‘22 will more than likely have more plastic to make it less of a pig. Unless the warthog comes out and they can adjust gvwr due to that heavy beast.
JMBGlass
JMBGlass
Josh
I've bought two new Toyota Tacoma pickup trucks before but I'm new to this I suppose because options didn't seem to be limited on those trucks due to weight. Thanks for info about what Ford's thinking is on limiting those options. So do you guys think a roof rails and sound-deadening headliner will be easily able to be installed by the dealership then? I'm still left wondering though how "paint protection film" puts the weight over the top for their calculations.. And is the Badlands really that much heavier than the other editions? If so, will acceleration and fuel economy just be awful?
Jpeyer
Joshua
Ohio
2017 F250 Lariat
Badlands and fe will have the worst fuel economy. Oem roof rails will most likely need a compatible vehicle vin for them to order initially. Headliner is just glued on. You will be able to get oem or aftermarket and diy.
jxc
Chester County, Pennsylvania
Accord/CX-5/A5 Cab
Hi there,
Noob! :) - JK, welcome to the @#$% show! - B&P is jacked + GVWR. - This was discussed ad nauseam when B&P was released. Lots of weirdness - I.E. - you can add a winch and mount but not paint-protection film...
