Did you readjust your clip position settings? Earlier, you posted something different:FWIW, I did the 1st clip position (lowest) on both front and rear, came out with approx. 2” lift (after settling). Bronco is level now and I l8ke the fact that if I add more weight at either end I can adjust.
And the ride/handling is sooo much better than the stock Hibachis…
”I used clip setting #1 in rear and #2 in front which gave me approx. 1.75” lift in rear and 2.2”lift in front. Front has since settled to approx 2”lift. Keep in mind I’m lifting a non-SAS OBX and had the complete Bilstein 6112 coilover units installed (including Bilstein springs).”
