- Thread starter
- #1
Anyone else run the Stadium wheel? Where did you find hub centric rings? Nobody seems to make rings for 112.1 to 93.1. Thanks in advance!
Sold out, but you could contact seller. Black Rhino to Bronco/Ranger.Anyone else run the Stadium wheel? Where did you find hub centric rings? Nobody seems to make rings for 112.1 to 93.1. Thanks in advance!
Thanks. I just ordered a set. We’re going to see how they work soon.US wheel adapters will custom make hub centric rings in any size you need (polycarbonate or aluminum). I had a set made for the wheels I plan to install, if my bronco ever gets built... 100.3mm to 93.1mm.
good luck!
Sorry I canceled the order. The correct rings were included with the wheels. There did not appear to be any flange.I have to order the same size for my black rhino overland's, did you order with or without the flange?
Where did you order the wheels from?Sorry I canceled the order. The correct rings were included with the wheels. There did not appear to be any flange.
