- First Name
- Roman
- Joined
- Dec 11, 2022
- Threads
- 3
- Messages
- 42
- Reaction score
- 42
- Location
- North Royalton, Ohio
- Website
- www.neo-garage.com
- Vehicle(s)
- 2023 Bronco Raptor, 2022 F150 Raptor
- Your Bronco Model
- Raptor
- Thread starter
- #1
We have a few more Eibach stage 2 systems in stock, these have been hard to keep and are a massive improvement over stock suspension while also offering an adjustable coilover system without breaking your wallet.
DETAILS
THE GOOD STUFF!
: Free Shipping Included
: 10% OFF use code EIBACH10
: NO LEAD TIMES
Order online here;
https://www.neo-garage.com/products/2021-ford-bronco-eibach-stage-2-coilover-system
PICTURES
Please reach out with any questions!
www.neo-garage.com
[email protected]
216-834-9557
DETAILS
- With consideration to the Bronco's capable chassis, it was our priority to maximize performance, ride quality and lift on all trim levels. Height adjustable threaded bodies allow you to easily dial in ride heights to fit larger tires and increase ground clearance.
Eibach\’s in-house development and manufacturing gives us the ability to fine-tune the combination of spring and shock performance. Using progressive coil spring design, our solution delivers optimal suspension travel. In addition to as much as 4" inches of lift*, each shock features extended monotube design and variable force valving to deliver control during on-road transit and compliance for maximum traction on the trails. All made by Eibach in the USA.- Pre-assembled for direct bolt-on installation
- Utilizes our ERO Championship proven Off-Road racing springs
- Designed to work with factory control arms for an increase in height without accelerated wear to ball joints and bushings
- Developed specifically to provide a balanced ride quality on and off-road
- Made by Eibach in the USA
- Included:
2 – Front PRO-TRUCK Coilover 2.0 Shocks
2 – Rear PRO-TRUCK Coilover 2.0 Shocks
1 - 6mm adjustment spanner wrench & all required mounting hardware
Ride Height:
* heights vary per trim level, see application listing for measurements.
Part Number: E86-35-056-01-22 | ||
Model | Front | Rear |
2.3L Non-Sasquatch 2.7L Non-Sasquatch Big Bend 2.3L Non-Sasquatch Big Bend 2.7L Non-Sasquatch Black Diamond 2.3L Non-Sasquatch Black Diamond 2.7L Non-Sasquatch Outer Banks 2.3L Non-Sasquatch Outer Banks 2.7L Non-Sasquatch | +1.6 - 4.1" | +2.3 - 3.8" |
Badlands 2.3L Non-Sasquatch Badlands 2.7L Non-Sasquatch | +0.9 - 3.4" | +1.6 - 3.1" |
Sasquatch 2.3L Sasquatch 2.7L Wild Track 2.7L First Edition 2.7L | +0.5 - 3.0" | +1.2 - 2.7 |
THE GOOD STUFF!
: NO LEAD TIMES
Order online here;
PICTURES
www.neo-garage.com
[email protected]
216-834-9557
