Capable Bumper Fog light plug
CMillBronco
Craig
2024 GMC HD 3500 AT4, 2022 Toyota Tacoma TRDORP, 2023 4Runner TRDORP
Anyone know if there's an adapter plug to go from the Capable bumper wire harness light plugs to an aftermarket lights?
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
CMillBronco
CMillBronco
Craig
4x4TruckLEDs.com
Adam
Lindenhurst, NY
I don't need lights just the wire adapters.
Well what kind of lights/kit are you rocking? There's lots of different pigtails depending on the lights
CMillBronco
CMillBronco
Craig
Baja Designs but I can do done adapters or I have everything I need to complete the light side.
4x4TruckLEDs.com
Adam
Lindenhurst, NY
What Baja Designs kit? The Baja Designs fog kit COMES with pigtails...
4x4TruckLEDs.com
Adam
Lindenhurst, NY
I don't have a kit or pigtails!
Where did you get your lights? You need the baja kit to make it work/fit. You can't just buy baja lights and install then. There are not only pigtails required but also mounting brackets that come with the kit
CMillBronco
CMillBronco
Craig
So you're asking questions way beyond what I'm looking for and I know it's only to help. I have Baja Designs lights from my UTV a modular bumper not capable now as I upgraded from my last Bronco and a Mod bumper mount. Sooooo I simply need 2 adapter harness's to plug into the factory Capable harness that came on my Capable bumper to work with my factory fog light switch for fogs, I have everything else I will need to attach my other BD lights to AUX switches, make sense?
4x4TruckLEDs.com
Adam
Lindenhurst, NY
That makes more sense. Because we've had customers just buy lights and go "hey these don't fit"
Now the other question I have is... how are you mounting the lights? You can't just mount the Baja Designs lights to the mod bumper not without another bracket system. You need another Bronco specific/modular bumper specific mounting bracket in order to get the fogs to mount. Otherwise they just have nowhere to mount to.
We sell some brackets here: https://www.4x4truckleds.com/kr-off...ckets-for-2021-ford-bronco-hd-modular-bumper/
And since your truck came with a Capable bumper and has that wiring, here are the pigtails you need (which would have with a fog kit, but you're re-using older lights): https://www.4x4truckleds.com/crysta...2021-ford-bronco-w-plastic-or-capable-bumper/
CMillBronco
CMillBronco
Craig
I have a mount already.
The harness side doesn't look right are you sure? Here's a pic of what I need.
Ford Bronco Capable Bumper Fog light plug Bronco fog light harness
4x4TruckLEDs.com
Adam
Lindenhurst, NY
The pigtail I sent you is correct
CMillBronco
CMillBronco
Craig
