Already happened.I’m waiting to see someone put the Warn/Ford winch onto the capable bumper as I believe it uses the same mounting points.
Do you have any measurements on how much you had to cut on the plastic cover? I’m looking for width and height ideally. And did you dremel it out or use a different tool? I’m attempting this on Monday! Thanks in advance!!Thanks! Yes- Same three bolts. Will need to trim the top steel tab on the bumper that the plastic cover around the tow hooks. Also, a tad bit of the plastic cover needs trimmed as well. That part will be self explanatory if you try it.
