Cleaning / removing Mud on the undercarriage?
JRMFFL531
J.R.
Does anyone have any techniques to remove mud that’s hardened underneath the undercarriage of the bronco? Short of climbing under?
imOFP
PNW, WA
M2C, BRaptor
A sprinkler and time.
Orbit 3000 Sq Ft Oscillating Lawn Watering Sprinkler, Tri-Lingual https://a.co/d/2vAbt9a
JRMFFL531
JRMFFL531
J.R.
Thank you. Lol
userdude
Jared
Denton, TX
2023 2dr Badsquatch
If you go the pressure washer route, having some ramps to pull up on can help if you don't want to get down closer to the ground.
JRMFFL531
JRMFFL531
J.R.
I tried the power washer and thought I did a solid job rinsing it. Then I took it to the automatic car wash. I looked today and it’s hardened all on most parts like cement. That can’t be good.
userdude
Jared
Denton, TX
2023 2dr Badsquatch
Welcome to off roading in many parts of Texas. Especially watch out for Texas black dirt; that stuff is like rubber cement. You just about have to scrape it off.
Put some water on it, get it nice and soaked, and come back a few minutes later and keep doing that, it should soften and fall off. You might also look for a good hand car wash with good water pressure. The second and third (and fourth) passes is what works for me.
Sir915
Shawn
El paso
2023 Bronco
Like others stated just soak it all over let it absorb the water then work each section but don't blast any electrical connections.
JRMFFL531
JRMFFL531
J.R.
It seems caked under the front bash plate, and the arms of the steering columns. (Please forgive my lack of nomenclature. I am not mechanically inclined and learning on the fly.) I’m guess the electrical connections are near the front like headlamps etc
Toccoa
Isuzu Rodeo Sport
You can soak it, but don't let your Bronco stay in the bath too long. :LOL:
Ford Bronco Cleaning / removing Mud on the undercarriage? 1701200498404
Ford Bronco Cleaning / removing Mud on the undercarriage? 1701200608622
JRMFFL531
JRMFFL531
J.R.
Yikes. I’m sure that type of my mud is hard to get off the old twig and berries
JT58Bronc
JT
Fl
2022 Bronco, 2021 Miata track Edition
Garden hose on full stream or high pressure to remove most of it. (or pressure washer on light setting). The remainder have to get underneath when it is still wet and soft and use a sponge or cloth with a bucket of water and wife the rest of it off, wringing out the sponge or cloth often.
Who iz
Otis
End of the Oregon trail
F250, 4Runner, Jimmy
Sorry, but it is now time to get close and personal to the under carriage of your Bronco. A simple stiff bristle brush & for the detail -crevices- a brass tooth brush, dip the brushes in some Murphy's oil soap while it is securely up on the ramps, remove the bash plates (easy). rinse well, and smile... it is more fun than the dentist.
You will be dirty and recommend keeping your mouth closed... Wear eye protection and a bandanna over your nose and mouth... covid mask could work too...but I personally dislike those stupid things.
JRMFFL531
JRMFFL531
J.R.
Sounds like it’s time to give the Bronco a “GI Party” military style. lol.
