DIY hard rear cargo cover
Rem234
Illinois
20 Veloster N, 11 Buick Regal, 02 Lesabre
I had been waiting for it to get consistently warm enough here in Illinois to completely remove the soft top so I could continue working on my hard cover. I made a cardboard template over the winter, but plan to use the soft top mounting point for the front supports so I needed it out of the way to proceed. The cover is a piece of 3/8 thick HDPE. As you can see in the photos it sags some so I am now working on some support bars and the attachment brackets. I'll post up all the details once I get it completed, but my plan is to have it removable with just four bolts or thumb screws. The purpose of this cover for us to provide some semi secure (out of sight) storage, keep sun and some weather off of our tailgate mounted sub box, and increase the subs performance with the top off by providing a "chamber" for the sub to fire into. That being said when I am finished if it resonates or rattles I may have to add some dynamat to the underside.
Ford Bronco DIY hard rear cargo cover PXL_20220531_004901444
Ford Bronco DIY hard rear cargo cover PXL_20220531_004853186
Rem234
Rem234
Illinois
Update with a couple more pictures. The cover does a great job of keeping stuff out of sight and improving the bass.
Ford Bronco DIY hard rear cargo cover PXL_20220615_004430504
Ford Bronco DIY hard rear cargo cover PXL_20220615_004419836
GreenbeanBob
nj
2022 Black Diamond
I owned an '86 SAAB hatchback a zillion years ago. From the factory, the cargo area had a carpeted cargo area cover made of plywood that worked great.
Found an image of the underside of one (not mine)
Ford Bronco DIY hard rear cargo cover tJ8IVE
604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
We use pineapples for measure of size on B6G, but your banana is a weird and intriguing flex... :unsure:
NORCALGXP
Sacramento, California
2017 Raptor
Update on adding supports? Very cool I like the look.
Rem234
Rem234
Illinois
Did not need to do anything to the supports. The cover worked awesome all summer long. I removed it a couple weeks ago to put the soft top back on for the winter. Honestly, I don't think I will mess with making it hinge open next summer, since we never really needed it to move this year. Here are a couple more photos of the rear mounting points that I took.
Ford Bronco DIY hard rear cargo cover PXL_20220814_231906015
Ford Bronco DIY hard rear cargo cover PXL_20220814_231913768
JetG
Jet
TX & FL
2018 Macan Turbo w/PP & 2016 911 Turbo Vert
What is holding it in place? Cant really make it out in the pics on how it is kept in place. Awesome idea and more than likely the way I will go with my Brapror.
Rem234
Rem234
Illinois
At the front there are 90 degree brackets that slide over the soft top attachment point locating pin and then are held in place with a bolt into the soft top mount point. This is then attached to the front cross bar.
At the rear the aluminum toe clamps pinch the soft top latch points between them and the rear cross bar. They are just a piece of 1/2" aluminum machined to an "L" shape with a 5/16 threaded hole in the one side. Here are a couple more photos I don't think I had posted before.
I feel like it would be fairly simple to make it hinge at the front and then use some spring latches at the back, so it could be opened. But this is the second summer I have used it and never needed it open for anything.
Ford Bronco DIY hard rear cargo cover PXL_20220601_221456597
Ford Bronco DIY hard rear cargo cover PXL_20220602_234537641
Bheemsoth
CT
2023 Bronco Badlands
Great build! Will this fit with the soft top attached?
Rem234
Rem234
Illinois
No, I only put this on when I take the top off for the summer. That is how I was able to use the soft top mounting locations to attach the cover. Here is a current photo.
Ford Bronco DIY hard rear cargo cover PXL_20230524_221243198
Rem234
Rem234
Illinois
It also makes a great standing taco table...
Ford Bronco DIY hard rear cargo cover PXL_20220826_221653208
GAN
Gan
RI
Bronco Badlands, Ford Escape, Hyundai Tucson
With doors off is there any way you've considered to secure the rear seats to the cargo area?
Rem234
Rem234
Illinois
Originally i considered disconnecting the seat latch cable or putting a couple bars across behind the seats, but it's honestly difficult to get the seat down and reach into the back without climbing up onto the step or door sill. I figure anyone willing to do that will figure out how to defeat a latch or lock, or just pry open the cover. This will be our third summer keeping the top and doors off from June till October and fortunately have not had any issues so far.
GAN
Gan
RI
This is true. Thanks for the quick response!
Bbaliatico
New Jersey
2022 Bronco
everything in those cars worked great - had an 83 900 Turbo
