Does the bronco normally have a tight steering feel?
JT58Bronc
JT
Fl
2022 Bronco, 1987 Chevy Squarebody 4 X 4
I think the steering on my 2 door Sas is just awesome. Tight and just the right feel. So tight compared to a brand new Jeep Gladiator I test drove back in 2019. That Gladiator had the sloppiest steering of any vehicle I have ever driven. My 97 TJ was better.
Hdscreens
Will
2dr Bronco Badlands
I’m almost sure they did cause it should be electric steering on that model year ranger and not power steering.
If steering rack is different for 2.3 and 2.7 I wonder if the assembly line put in wrong steering rack on op’s Bronco?
I had a 2021 ranger tremor and I think they forgot to put power steering on it lol. It was way hard to turn. Got my obx squatch bronco and it's right about where I think it should be. Ten fold better than the ranger.
omi205
BoJack
Austin
I think its relative but short answer, yes. Compared to my wrangler, for sure 100%. No wiggle room. I love it like that. Its direct and doesn’t play around. I can only speak to a stock badlands sas package. I would have it no other way. It reminds me of driving a BMW. Heavy steering wheel with no play and any movement in steering leads to movement in the tire. Again, I love it but others might not like it. It makes me feel confident…not like im driving a toy. Most German vehicles also have a similar heavy steering. I associate heavy steering with quality.
jddunfee
Indiana
2021 Ranger Tremor
Yah, I was kinda kidding about the no power steering. It was electric but didn't assist much at all. The bronco electric power steering is set up nice on mine. 👍
Earlybroncoboy
Earlybroncoboy
Wagner
Pa
22Bronco,76bronco,73bronco,06F250,96F250,97F350
My steering feels pretty light with little or no feedback. Mine is a 2.7 2 door. The steering is fairly numb, but light. Turning circle is quite small on the 2 door as well.
I think I read somewhere that the power steering system is different between the 2.3 and the 2.7. Could that be what you're noticing?
What do u mean by numb?
Earlybroncoboy
Earlybroncoboy
Wagner
Pa
That’s how mine feels I’m not particularly crazy about it. I wouldn’t imagine the badlands sas steering program or components to be any different than the other models but maybe. Sure feels different than my last two. Maybe I’ll just get used to it. Thanks for you feed back
rguest3
Raymond
Florida and Virginia
F-350, F-450, 23 Bronco, 24 Raptor, (2) 77 Broncos
Too much Castor will make the Bronco want to stay straight and this may seem to make the steering feel tight.
checking the steering rack and alignment check may reveal the cause of the tight felling steering.
Earlybroncoboy
Earlybroncoboy
Wagner
Pa
Yes good thought I to had a thought about castor. Nothing I did would have effected it but I checked it anyway. It was at the low end of the spec at about 3 degrees. I’m not sure what I would check for on the rack. Seems to steer fine when not moving. Any suggestions.
Earlybroncoboy
Earlybroncoboy
Wagner
Pa
Update to issue. I had the steering rack replaced due to corrosion inside the rack. Steering is still extremely heavy. Other things have tried.
lowered castor to +2.6 no change
Changed toe to almost zero no change
Removed and Inspected steering shaft no binding
Tried various tire pressures no change
Almost has to be a software issue at this point. Anyone know if there has been any software updates to PSCM over the years? Both My 22s drove flawlessly.
Anyone be willing to share there strategy and calibration codes for the PSCM from forscan so I compare with mine?
I may start a new thread to try and collect that info
Felix808
SRV CA
Doesn't sound good. I would pull the inner tie rods & boots. Then run the rack end to end checking for metal shavings each time on each side while checking the inner rack bushing.
Earlybroncoboy
Earlybroncoboy
Wagner
Pa
Doesn't sound good. I would pull the inner tie rods & boots. Then run the rack end to end checking for metal shavings each time on each side.
Rack is brand new was just replaced. No change to steering feel with new rack
Felix808
SRV CA
🤷‍♂️ But it should be consistent limit to limit. Are you moving when turning or trying to turn from a standstill? What type of surface are you on?
Good luck with it.
