Door Hinge Bolt Size Gauge?
Mikey D
Ormond Beach, FL
www.mikedelninno.com
2005 Ford Explorer
Anyone know size and gauge of door hinge bolts for upper and lower? Couldn't find specs in manual and would like to get spare set. Or, I guess I could remove while sitting in the nut/bolt parking lot and run in while doors hang.
Dzrt1st
Roy, WA
BadSquatch, Toyota Tundra, RX7
It should be the same size and thread pitch as the Door Alignment Pin that came in you toolkit.
Mikey D
Mikey D
Ormond Beach, FL
2005 Ford Explorer
Will probably head over to nut and bolt and bring in so they can match.
Ground_zero298
Scs michigan
M8
Ford Bronco Door Hinge Bolt Size Gauge? imag
Ground_zero298
Scs michigan
2 different ones:
M8 -1.25x35mm flange bolt on top
M8 -1.25x16mm flange bolt on bottom
Mikey D
Mikey D
Ormond Beach, FL
2005 Ford Explorer
