DV8 Offroad | Spare Tire Guard & Accessory Mount
DV8offroad
Riverside, California
dv8offroad.com
Bronco's & Jeep's
2021-2023 FORD BRONCO | SPARE TIRE GUARD & ACCESSORY MOUNT
The Bronco Spare Tire Guard was designed with several functions in mind. After upgrading to larger tires, the spare tire has been known to cause flex in the tailgate due to the added weight on the factory carrier. The tire guard reinforces the tailgate by mounting to multiple points along the tailgate, increasing rigidity. Additionally, the guard can accept locking pins (not included) for security against theft.
The tire guard can fit up to a 20-inch wheel with a 37x12.50-inch spare tire. The OEM back-up camera retains full visibility when using the tire guard. Installation is a simple, bolt-on process with no drilling required.
* Please Note: This is NOT compatible with the Ford HD Tire Carrier. A high offset wheel will require 1.5” wheel spacer or ET lug nuts. This is not compatible with -44 offset wheels, or any wheel wider than 9.5.”
Check it out here: https://dv8offroad.com/products/6th-gen-bronco-spare-tire-guard
Ford Bronco DV8 Offroad | Spare Tire Guard & Accessory Mount bronco-spare-tire-guard-armor_1051x700
Ford Bronco DV8 Offroad | Spare Tire Guard & Accessory Mount ford-bronco-spare-tire-guard-armor_1051x700
Ford Bronco DV8 Offroad | Spare Tire Guard & Accessory Mount d-bronco-spare-tire-guard-accessory-mount_1051x700
Ford Bronco DV8 Offroad | Spare Tire Guard & Accessory Mount n-bronco-spare-tire-guard-accessory-mount_1051x700
KEY FEATURES:
  • Recommended for 4”+ Backspacing
  • Accepts Up To (Most) 37" Tires
  • Multiple Mounting Points Offer Reinforcement For Tailgate
  • Paintable Aluminum Panels
  • Does Not Interfere With Back-Up Camera
  • Can Accept Locking Pins For Increased Anti-Theft (Not Included)
  • Quick And Easy Install
Visit https://dv8offroad.com/pages/ford-bronco-bumpers-and-accessories to shop all of our Ford Bronco Parts and Accessories.
Plus... use code "ForumMember" at checkout for 10% off!
SubmarineNuke
Richard
Houston, TX
twitch.tv
Bronco Wildtrak
that's appealing...I like the look a LOT
Aztec1382
Sam
F350
Looks sweet
AK SNO RIDER
Ty
Alaska
Man, that looks awesome, exactly what I've been looking for. Was about to order, but at 54 lbs I'm second guessing. Seems like an awful lot of extra weight to hang on the tailgate
