New Jersey Eittar throttle booster $45
JL8jeff
Ewing, NJ
This is an Eittar 9-Drive throttle booster for various Ford cars/trucks. It allows you to fine tune the throttle response of the electric gas pedals with over 27 settings. The number on the back is 9P-261 and I know it works on 2021-24 Broncos and probably most of the recent Fords. Check your wiring connector at the pedal if you're not sure but I'll double check the applications. I ran it on P1.4 for a sportier feel without being too jumpy. It helps make the vehicle more drivable with no hesitation. $45, shipping extra.
Ford Bronco Eittar throttle booster $45 ford_eittar6
Ford Bronco Eittar throttle booster $45 ford_eittar7
Ford Bronco Eittar throttle booster $45 ford_eittar8
Ford Bronco Eittar throttle booster $45 ford_eittar2
Ford Bronco Eittar throttle booster $45 ford_eittar3
Ford Bronco Eittar throttle booster $45 ford_eittar5
Ford Bronco Eittar throttle booster $45 ford_eittar9
0ne
Nate
CO
Flex
Hi did you sell this? If not did you confirm the application? I’m assuming it was on your Bronco? Why did you remove it? Thanks
JL8jeff
JL8jeff
Ewing, NJ
I actually just put it back on the Bronco Friday. I took it off because I got the FPP tune, but even with the FPP tune, this does help with the throttle response. I turned it down to P1.2 or 3 because it was a little too jumpy at P1.4 with the tune.
  • Like
Reactions: 0ne
