- Chris
- Aug 12, 2021
- 78
- 389
- 1,403
- Fort Myers
- Website
- www.stickerfab.com
- 2021 Bronco Badlands / 2023 Bronco Raptor
- Raptor
So this is something that a few customers requested for a bit. It just never struck me how we would make sure we didn't damage the original stickers. If you didn't care, you would just rip those off to begin with right?
Well we start with a layer of laminate protector. A thin PPF if you will. Run around the vehicle and install those with a cup of water mixed with 1 drop of dish soap or preferably our StickerFab Application Fluid. Use a felt lined squeegee once you find the proper position and get the bubbles out. Let dry.
Then come back and repeat it with the colored vinyl of your choice. Of course vinyl can only get so close to actual paint colors, but from normal viewing angles they will basically disappear into the paint. Eyesore gone.
https://www.stickerfab.com/products/door-sticker-cover-up-kit-printed-series-2021-2023-bronco
Should you ever need to remove it, carefully just peel off the colored cover up and leave the clear portion. Then your factory labels will remain pristine.
Comes with 5 small covers for the door warning that is on every door jamb, a larger rectangle for the vehicle info sticker (driver only), and a slightly smaller one for the tire pressure sticker (driver only).
