Flat tow bumper winch combinations?
Tilzbow
NV
GM Sierra Diesel Pick Up
Tilzbow
NV
Bodyguard are also flat towing compatible, per an email response I received from them, shouldn’t block the camera too much and they do sell a camera relocation kit for the version with the Baja bar.
https://www.bodyguardbumpers.com/bronco-front-bumper
Lastly, JCR is releasing one soon and they’re working on a camera relocation kit. I’m not certain their option will be flat towing compatible since it’s still in the prototype phase. On the attached thread start at about post 207 and on.
https://www.bronco6g.com/forum/threads/jcroffroad’s-bolt-on-steel-bumper-parts-hoops-more.29264/
Warn‘s Elite bumper appears it might work but they responded to an email I sent stating it’s not rated for flat towing.
My concern with most options that place the winch in the area that won’t block the camera is restricted airflow to the intercooler. See this thread for responses on that.
https://www.bronco6g.com/forum/threads/winch-placement-and-intercooler-air-flow-any-concerns.31569/
The Ford Performance winch kit looks to be flat towing rated but after 2 hours on the phone with three different departments at Ford, including a Ford Performance tech, no one could or would confirm it‘s rated for flat towing. That option will of course require the camera to be relocated.
That‘s all I’ve been able to find so far after watching closely for several months.
72BroncoSand
PNW
72 Bronco, 77 f-150, Jetta Tdi, 1ton
NVCowboy
William
Henderson, NV
Yes, but is the wench quite or noisy?
wrbix
VA and FL
LR Def90, F250 7.3, Caterham 7, LR Series III, etc
It’s also important to know the duty cycle of any wench you’re considering.
