Ford Performance Winch Camera Relocation Bracket / Kit
FordOwner
SoCal
a few
I finally got around to installing the Ford Performance Winch that I've had sitting in the garage for a year and a half, pairing it up with a modular bumper I recently acquired.
I next need to improve my front-facing / 360 camera situation and am looking at options. Here are some I've seen out there, not including a few low-cost, home-made one's. I think I've seen threads that say you can buy 4 - 4.5ft of washer hose at your local auto parts store and a camera extension cable can be found for under $10.
JCR - $149.00 This post says it did not fit with warn fairlead & factory bullbar.
M2M - $179.99 Pricey but seems like a leading contender as it works with factory ford winch mount & Includes harness extension and washer hose extension
DV8 - $153.99 Adjustable for different setups
Turn Offroad - $149.00 Comes with lengthened camera cable and water hose
Rough Country -$69.95 Looks too high a mount for the factory ford winch & no extensions?
Tioyar - $69.99 Looks to be a dv8 copy but no harness and washer hose extension?
SmittyBuilt - $109.99 Harness and washer hose extension included, but might not fit warn winch?
What else is out there, and any recommendations or criticisms of what you've tried?
FordOwner
SoCal
a few
I went ahead and ordered the Mountains to Metal (M2M) kit since it was built to specifically work with the Modular Bumper and Ford Performance Winch Kit. The kit happened to be priced lower when I made my purchase plus I was able to use the 10% off Memorial Day code.
The install took about an hour. The hardest parts were removing the plastic trim panel clips without damaging them and routing the new washer hose wiring, neither of which was particularly difficult.
Before and after photos of the camera view in Baja mode with the winch installed.
Before M2M install:
Ford Bronco Ford Performance Winch Camera Relocation Bracket / Kit PXL_20260527_205441299
After M2M install:
Ford Bronco Ford Performance Winch Camera Relocation Bracket / Kit PXL_20260528_012607289
OtisFE
Otis
Palm Coast FL
2022 Bronco OBX
I used the M2M and very happy with it.
