What is @Ford doing?? These instructions are absolutely worthless. No mention at all of multiple things that would be good to know. Two bolts had to be removed, not a word about. Not a mention about airbag and what your supposed to do with it. Mid trim on door needed to be removed to get the corner piece out in order to locate wires. Because this wasnt mentioned one of the weak plastic welds around the little vent on backside broke.The rigid wiring is not long enough to make connections. Not a word about the white wire coming out of the light bar which according to rigid is for back lighting. Looks like i will have to go to store tomorrow to buy wire for extending the connection.
Have you looked up a few video installs? This one went through the wiring. It's not a Rigid, or roof rack light bar, but wiring route should be the same. Hope this helps.
